Kingston (DTIU3/2GB) 2 GB USB Hard Drive Logo
Anonymous Posted on Jun 11, 2010
Http://www.apacer.com/en/support/downloads/Repair_v2.9.1.1.zip .... that link doesn't work on me, it says, USB flash disk is not found! .. whay do i do??
1 Related Answer
Subhankar Ghosh
  • 180 Answers
  • Posted on Jan 04, 2011
SOURCE: Can any one help to fix my problem "Device is
To fix this problem you can try these steps.
Just click HERE and check whether they help or not.
It will help you.But if it still not helps then please get back here.
All The Best
Thank you for using FixYa.
With Regards:-
Subhankar Ghosh
How to remove write protected in my 8 gb transcend pendrive
If there is no prot/unprot switch on unit (very small!) then try this link
http://www.apacer.com/en/support/downloads/Repair_v2.9.1.1.zip
from another make but said to be good.
My kingston 32 gb pendrive is giving a write protected error. what should i do
SOLUTION 1) Try this...Go to http://www.apacer.com/en/support/downloads/Repair_v2.9.1.1.zip
(the software is model/manufacturer independent.)
Be careful to have only the flash drive you need to repair connected to your computer, as the software has no controls, and doesn’t even allow you to choose which drive you want to format - seems like it assumes the first removable drive available is the one you want to format. If the format "fails" then quit the tool , then try format in Winxp. SOLUTION 2) Check out the registry under
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\StorageDevicePolicies.
The value 'WriteProtect' should be absent or set to '0'.
3helpful
! C:\Downloads\AH320_Utility_LFormat.zip: The
Found this on Tom's Hardware - link still works Apr2010.
It's simple: download this
http://www.apacer.com/en/support/d [...] .9.1.1.zip
run it and it will format your USB even if it is write protected.
Good luck!!
1helpful
Usb drive says write protected
download the tool from http://www.apacer.com/en/support/downloads/Repair_v2.9.1.1.zip.
This will solve your problem
Win 98 machine won.t accept new apacer AH323 flash drive - needs to get a driver downloaded from internet free. I cannot locate the appropriate website for this
here's the driver you need for your win 98 machine
go to this link
http://www.apacer.com/en/support/downloads/WIN98DRV.zip
Usb drives show write protected when plugging in any device
ok, i found having the flashdrive in a usb hub doesn't help this (http://www.apacer.com/en/support/downloads/Repair_v2.9.1.1.zip ) repair kit to work cuz it can't recognize the flash drive.
so i took ejected it and put it straight into the computer usb and then tried again to format it and hooray. it formatted.
so i managed , thanks
adele
My pny 4g is write protected what can i do to fix it?
format it and try to run this application..here's the link,
http://www.apacer.com/en/support/downloads/AH320_Utility_LFormat.zip
it worked for me,so i hope it will also work for you..
Ms.Waqui
How do i re format a write protected usb drive
it worked for me,so i hope it also work for the both of you..
Ms.Waqui
phil
Top Kingston Computers & Internet Experts
Jean Thiebaux
Are you a Kingston Computer and Internet Expert? Answer questions, earn points and help others
