Question about Brother XL-2600
What are the best settings on the 4 dials for the straight stitch? Do the ones on top have to match the wheel settings below? Thanks from a novice
Anonymous
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 53 Answers
#1- tension settings, set this to "5" and leave it
#2- width control setting, 0 would be straight while 5 would be the full width of the stitch (would make a wide zig zag)
#3- Length control, larger the number, longer the stitch. (usually you will set this from 1.5 to 2.5)
#4- Stitch selector, match up the number with the stitch you want to sew. If you want to use the lower row of stitches (14-25) set the length dial to "ss". (ss stands for stretch stitch, such as for #14 (three rows of straight dashed lines) instead of just sewing one stitch forward, the machine will sew back and forth giving you a stretchy stitch/stronger)
Let me know if you need more help :) Chris
Posted on Jun 12, 2010
Testimonial: "Thank you very much, Chris Myers, for your full, clear, and generous response to my question. The photo of the machine with the directional arrows is an illuminating supplement to your text. I think Brother should incorporate your response in their manual for all us initiates. Much gratitude, Maryanne"
Cookie Pieczonka
    New Friend:
Thank you so much for the diagram!! My stitches are still a bit loose but this is the closest I've gotten to getting the problem figured out. I think I can figure out the rest now. :-)
Posted on Dec 09, 2012
Nina serger tension settings. Straight stitching gathers up or breaks.
Is that a Bernina? Which model?
Usually, if you are experiencing improper stitching and/or broken threads, it's most often a mis-threading problem. Proper threading is EXTREMELY important to successful serging.
Remove all the thread from the machine. Use colored threads that match the machine diagrams.
ALWAYS RAISE the presser foot when threading!
Thread each thread in the ORDER specified. Usually, Upper looper first, then Lower looper, then needles.
When threading each, grasp the thread below the thread tree and below the tension dial, and give it a tug to seat the thread completely. Sometimes it will pop when it seats. If the stitching has loose looping threads, most likely the thread is not seated completely.
Verify the thread path is correct for each thread before going on to the next thread.
The best tension setting is the midway point--usually marked on the dial. Then the tensions are tweaked following testing. The colored threads will help you determine which thread is misbehaving.
Mar 17, 2018 | Sewing Machines
I have a model 2380 and I HAVE NO IDEA HOW TO SET IT BACK TO A STRAIGHT STITCH. WHEN I SEYT THE DIAL TO "A" IT STAYS ON ZIGZAG. THE MANUAL DID NOT HELP
You need to select A but also set the Stitch Width dial to zero. The Stitch Width dial should be the one on top of the machine next to the handle.
https://www.manualslib.com/manual/776764/White-Sewing-2380.html#manual (page 25: Select Stitch Pattern A, Stitch Width to zero, Stitch Length to zero to 4)
Apr 29, 2017 | Sewing Machines
Singer xl-400 bobbin tread to loose when momograming
It means that your top thread tension is tighter than your bottom thread, and it's pulling your bobbin thread up. You loosen your top thread by turning the dial towards the "S." You should only have to loosen it by a maximum of one number; if it's more than that, you may have to adjust the bobbin thread tension.
You do that by first turning off the machine and removing the embroidery unit. Turn the tension dial to S. It helps to use a different color top and bottom thread, with the scrap fabric a third color. Run a straight stitch and zigzag stitch and examine them. If one size of the zigzag looks like "chicken tracks" or one side of the straight stitch is a straight line, it means that side is too tight. Take a look at your user's manual on page 11. If your top tension is on "S" and it is the side that is too tight, you will need to tighten the bobbin tension, to match the top tension. Tensions are a BALANCE.
The next step needs to be done systematically and carefully. If you don't, you can really make things worse. Set your mind to doing everything step by step--don't get tempted to jump ahead. Take the needle plate off and take out the bobbin case, and locate two screws on the side. One is a Phillips screw--leave it alone. The other is a straight screw--that's the one, and you will need a tiny screwdriver to adjust it.
The rule is "righty-tighty, lefty-loosey." Remember, you are trying to match the top tension! Give the screw on the case no more than 1/4 turn, reinsert and retest. You should see at least a little improvement. Keep doing that until you have balanced your stitches, and DON'T jump ahead! The difference between too tight or too lose is often a very small turn of that screw--especially when you're close.
Jun 11, 2014 | Singer Sewing Machines
I don't have a manual for a Husqvarna 6440 and don't know how to switch from zigzag to straight stitch. Everything else seems to be sewing beautifully and it was on straight stitch when I first tried it. I...
You have 3 knobs/dials on the machine, the top left dials the stitch, the top right sets the length and the bottom right set your width. set it 0 for straight.
Mar 03, 2010 | Sewing Machines
CANNOT GET THE TOP AND BOTTOM STITCH TO MATCH FOR STRAIGHT SEWING. I HAVE TRIED EVERYTHING. CAME USED WITHOUT INSTRUCTION MANUAL.
Please explain what you mean when say you cannot get it matched. For straight stitching you need to have the stitch dial on 2.
Jan 14, 2010 | Brother XL-2600
Ordinary straight stitching
When you turn on a #1 Husqvarna Viking the machine defaults all the electronic settings to do a straight stitch at a 2.5mm stitch length, that equates to approximately 10 stitches per inch. The top tension dial sets itself automatically and the only other dial is on the left side of the machine. That dial sets the pressure on the foot that holds down the fabric. It's normal setting is 6.
Sep 02, 2009 | Husqvarna Viking 1
Factory settings for stitch length and width dials
I hope you have not left this machine for a year! (If you haven't used it, feel free to send it to me!) Since the tensions on this machine are automatically set with the automatic thread delivery system, check to see if you have stitch dial set for an overlock or a flatlock stitch (which is what you're getting now).
May 07, 2009 | Baby Lock Imagine
Proper Settings
A good standard tension setting is usually around 4.5.
If you find it to be looping on the bottom, raise your top tension. If it's pulling bobbing thread to the top, lower your top tension.
For straight stitch, your stitch width should be set to zero, although on some machines (and I believe your Baby Lock to be one of them,) the stitch width setting will change your needle position.
Stitch length is simply a matter of preference.
-R
Aug 14, 2008 | Baby Lock Ellure
Sewing newbie needs help
I haven't seen this machine before but in general, the most common problem is the bobbin. Either it's not wound correctly, poor thread or put into the machine wrong. Other wise wheel number 3 looks like a stitch selection dial to me. Try turning it and see what happens to the needle. When you change from straight stitch to say zig zag it would move right or left. On dial #2 isn't there some writing? What does it say? In general there is no need to change the tension of the bottom thread unless you are sewing extreme fabrics such as leather and silk. What is the range of numbers on the dials? Try putting them in the middle of the range to see if it has an impact of the quality of the stitch. My bet is on the bobbin thread not being correct. Try taking it out and putting it in so that the thread is traveling into the bobbin case from the opposite direction. I'd try this after taking out all of the thread (if it came with the bobbin) and reloading it. A straight thread on the top happens when the top thread tension is too tight if I remember correctly. It is stronger than the bottom and doesn't move so to speak.
Feb 03, 2008 | Singer Featherweight II 117
Brother XL-2600 Logo
1,196 people viewed this question
Top Brother Sewing Machines Experts
Irene Tulloch
Douglas Plant
Douglas Plant
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
