Question about Linksys RV042 VPN Router
I`m use linksys rv042 router I can try firmware upgrade. after firmware upgrade my router`s DIAG light comes on at that point. If I do a power cycle to it, often times, the DIAG light comes on a stays on. If I leave it unplugged for long enough, it will work for a few seconds then **** out again. I've tried the hard reset, but I'm getting the same problem.
Posted by btbld23 on
Anonymous
    Scholar:
  • 78 Answers
Sounds like a bad firmware updgrade,
roll back the firmware by redoing the upgrade with your backup that you made prior to the upgrade.
you made a backup right? they may provide older firmwares on the manfactures website linksys is usually good about this.
Posted on Jun 11, 2010
Linksys RV042 10/100 4 port vpn router keeps dropping connections. Is there a fix I have spent a lot of money with various poeple to help and no fix yet.
The problem with the router firmware can cause various disconnection issues. For solving these issues you have to reset your wireless router to its factory default settings. Do not forget to configure a new password after you have reset your router, otherwise anyone will be able to use your network. Also, ensure that you remove all the malware infections from your computer.
May 11, 2011 | Linksys : RV042 4-Port 10/100 VPN Router...
I lost power and when I unplugged and replugged the router, the only light that come on are the power and diag light
Hi!
You need to folloow the steps below if Diag Led lights keeps on flashing overtime:
Click start then access control panel Go to Local area connection - properties - internet protocol/TCP-IP then use the IP Address: 192.168.1.50 and Subnet Mask:
255.255.255.0. after these download the most recent firmware version for your router that can be downloaded from your router's manufacturer website. Restart your devices after firmware version upgrade.
Should you have any other questions just please leave a message.
Cheers~
Sep 09, 2010 | Linksys Wireless-G Broadband Router
I lost power, when this has happened in the past I just unplug and replug the router and it fires up with no problem, but this time it does not, the only light I have on the router is the power light and...
Hello
Yes, this is most probably the case. If you are very lucky you might have only damaged the firmware, but, it is a long shot. Have a look if a firmware upgrade does the trick, otherwise, sorry man.
Let me know if you found this helpful.
Kind regards
Andrea
Its restart after few times
just goto http://tinyurl.com/l65dx4 and upgrade the firmware.after upgrading reset your router and reconfigure it.your router will be fine.take care
Jul 13, 2009 | Linksys RV042 VPN Router
I have aproblem with my RV042. I cannot access the default web page. Upon entering the default Ip it will always display the upgrade firmware unpon entering the difalut IP
Here's what you need to you may need to reset the router first if you want to access the router setup screen (default settings),
resetting the router - have a paper clip and push the button there for 30 sec. turn off the router and turn it back on.
checked the IP address also of the computer, click start run CMD and hit okay. Then push IPCONFIG and check it the IP address, you should be getting 192.168.1.100 for the IP address and default gateway of 192.168.1.1..
Let me know what happens there..
Jun 05, 2009 | Linksys RV042 VPN Router
Firmware Upgrade Failed
Firmware upgrade is a simple but a delicate procedure. Make sure you are loading the correct firmware. You should get your firmware from the website of your router. Installing a THIRD PARTY firmware to your router voids the warranty of your router. Here is a tip for a successful firmware upgrade. BEFORE FIRMWARE UPGRADE(push the reset button of the router for 30 seconds then unplug the power of the router for 10 seconds). Upgrade the firmware. After the upgrade push the reset button again for 30seconds, unplug power for 10 seconds.
Mar 10, 2008 | Linksys Wireless-G Broadband Router
Linksys Wireless B BEFW11S4
That router should have a small hole on the back of the router (near the power plug, I believe) with a button inside. Use a paperclip to hold that button down for 5 to 10 seconds, then reset the power to the router, and it should be back to it's defaults.
If that doesn't work, the firmware is probably corrupted, and there's not a whole lot you can do about it.
Feb 12, 2008 | Linksys Wireless Ap + 4 Port Router...
I Upgraded RV042 to latest firmware from Linksys Site and now Router Continually reboots
i think there might have been some sort of virus(spyware, adware, trojan)
Dec 28, 2007 | Linksys RV042 VPN Router
Diag led
wat about the powerlight in the router....
Oct 24, 2007 | Linksys Wireless-G WRT54G Router
Linksys RV042 VPN Router Logo
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Mike
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
