Estate TUD8700SQ 24 in. Built-in Dishwasher Logo
Posted on Jun 10, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How can i tell which wire connects to the white and which connects to the black wire if there not color coordinated?
Gerald Griffin
Level 2:
  • Expert 248 Answers
  • Posted on Jun 11, 2010
Gerald Griffin
Expert
Level 2:
Answers
248
Questions
0
Helped
148424
Points
570
Looking at outlet and if the round ground hole is on the bottom, the white wire comes from the left side and the black, the right. Reverse if ground hole is on top.
What is order by color to airflow sensor 93:Dodge dakota 5.2'itr
Simple match up the colors of each wire but look for closely as some wires may for example be white and the other may be white with a black stripe on it. Just an example for all wires just be sure they match up with coordinating color. Good Luck.
3answers
Need to know what wires go were.what wires go to black-white-green.for 115v.
I'm not sure what your question is - it's not real clear.
What I can tell you though:
Black = HOT wire
White = Neutral wire
Green = Ground
Do NOT mix these up - always connect the wires to their same corresponding colors.
I'm sorry if this doesn't help - you might try searching the issue by your model number on either google or youtube.
Apr 07, 2015 • Pool & Spa
TV fell and now only have black and white picture No color.
if you were using a straight coax connection you might want to try HDMI, on a Cable or sat box or if you are using component connections make sure they're all color coordinated. just because one input may be damaged doesn't mean other inputs are damaged try using a Blu ray player you know is good, checking different types of connectors and different inputs. If you get the same results off all inputs then the tv has sustained damage, might want to check prices at Walmart cuz it ain't gonna be worth it to have it fixed
Want to attach a harbor breeze light kit to an existing hunter fan. switch housing has 3 white wires hooked together with a blue connector cap and a single black and white wire(labeled for light). there...
White to white ( single white ) & blue from light kit to Black with white stripe. Also make sure the black with white stripe coming out of TOP of fan is connected to the hot wire.
1991 Toyota Camry Ignition harness has different colord wires than those mentioned in the connection tables
Try looking at color codes for the year before and the year after, just never know.
Need to change the power corrd to a 4 prong from the 3 prong but the 3 prong cable isnt color coordinated, how do I hook up the new power cord?
The new cord has a green ground wire; two hot wires, which are black and red; and a white neutral wire. Attach the neutral to the middle connector and the two hot wires to either end of the terminal.
In order to safely ground the machine the green ground wire must be securely connected to the dryer frame. There may be a screw on the frame where you can attach the ground.
110 line in to light switch. How do you continue 110 line out to other oulets or switches?
Add another line to 120V switch.
To begin, inside your switch box, there must be at least two cables.
Each cable has a black-wire and white-wire and bare ground wire.
If your box has only one cable, then you cannot use that for your junction.
OK, your box has 2 cables.
One cable comes from circuit breaker box. These are called Line wires. There is a Black Hot and White Neutral.
The other cable goes to light. These are called Load wires.
You are going to add a new cable with a black-wire and white-wire
In back of box, the white wires are twisted together and covered with wire nut.
These white wires are called Neutrals.
Add your new white wire to these other white wires.
The switch has 2 black wires. One black wire is the Hot line wire.
Add your new black wire to the switch screw that has the Hot.
Of course the switch has 2 black wires, so how do you know which is the Hot.
Turn light switch off, turn power ON, and test each black wire to bare ground wire.
Tester lights up on the Hot.
Review:
New white wire connects to other white wires that are twisted together and covered with wire nut.
New black wire connects to Hot wire.
Ground wires are connected together.
On your new receptacle, the black wire connects to brass screw, and white wire connects to silver screw.
Screws are color-coded to tell electrician how to wire.
http://waterheatertimer.org/Color-codewire.html
http://waterheatertimer.org/B220C.html
http://waterheatertimer.org/See-inside-main-breaker-box.html
If you have 3 white and 3 black as well as a ground,how do you hook it up ?
If I understand correctly, your are replacing a GFCI receptacle with another GFCI receptacle
And your existing GFCI has 3 black and 3 white wires
And there is not a switch involved in the changeover.
I downloaded the manual from Lutron
http://classic.lutron.com/CMS400/techinfopage.aspx?id=22163
Every wiring diagram in manual shows:
Black wires connect to brass-colored screws
White wires connect to silver-colored screws
The brass and silver colored screws are typical of all residential receptacles. The color-code tells the electrician which terminal gets the black and white wires.
Are you having a problem putting 3 wires onto 2 screws?
It is a common problem.
You can buy a short piece of white and black wire at hardware store
Lets work on the black wires as example:
Strip back insulation on short piece of black wire
Hold together two of your black wires and start twisting them together
Now add the short wire to the two black wires you started twisting
Now twist together the two blacks and short black
So three wires are twisted together and you have a short lead that can connect to screw on GFCI
Put a wire nut over the twisted wire
Now you're ready to connect other end of short black wire to brass-colored screw
This reduces the number of wires that connect to screws
http://waterheatertimer.org/How-to-twist-electric-wire.html
http://waterheatertimer.org/How-to-select-right-wire-nut.html
What is the color coordination for a ford escort, i want to chance the stereo and the wiring colors don't match up
Here are factory wire colors from modifiedlife.com:
1995 Ford Escort Car Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Blue/Red
Car Radio Accessory Switched 12v+ Wire: Blue/Black
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Red/Black
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Violet
Left Front Speaker Negative Wire (-): Blue/Orange
Right Front Speaker Positive Wire (+): Blue/White
Right Front Speaker Negative Wire (-): White
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): White/Blue
Left Rear Speaker Negative Wire (-): Red/Blue
Right Rear Speaker Positive Wire (+): White/Green
Right Rear Speaker Negative Wire (-): Blue
If you have more questions, please reply
I need to connect an Alpine Stereo to a 12v battery in a boat. I know that that is not recommended but we got it used. I am not sure which wires to connect to where. Could you please help me?
Connect the yellow wire directly to the battery (this is constant 12v power, to maintain memory settings). Red wire gets wired to the switched 12v system (so that the stereo turns on and off with the ignition). Blue wire (or blue/white) would be for an antenna or an amplifier (if not used, just seal it off with electrical tape). Orange wire isn't used (that's a dimmer wire for tapping into a car's dash light dimming). Black is ground. The rest of the colored pairs (gray, gray/black, green, green/black, white, white/black, purple, purple/black) are the speaker outputs. The wires with the black stripes are the negative wires in each pair. They usually say on them which color corresponds to which speaker location (front left, rear right, etc). If not, take a look on the Alpine unit - sometimes there's a decal or diagram on there, or a list, which will tell you which wires to connect to which speakers.
Top Estate Dishwashers Experts
Mike Cairns
Mike Cairns
john h
Are you an Estate Dishwasher Expert? Answer questions, earn points and help others
