Logitech FreePulse Wireless  Consumer Headphones Logo
Posted on Jun 10, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Headphones wont turn on at all. (no lights) dropped once.
Anonymous
Level 3:
  • Master 10,594 Answers
  • Posted on Jun 10, 2010
Anonymous
Master
Level 3:
Answers
10594
Questions
9
Helped
2957530
Points
33084
Reinsert batteries in your head phone that can be dislocated due to drop.
Thanks.
Icandy bluetooth headphones wont turn on but it will charge help??
Sir i have a icandy freedom 180 headphones but i dont know how to charge them. It does not have any charging except for Aux port thanks. Kindly explain it with detail how to charge them thank you
1helpful
Headphones drop out
Cord is probably broken internally. If you are not good with wires and soldering and it is out of warranty, find someone who is or buy new headphones. You can manipulate the wire until it works and tape it in that position for a temp fix, otherwise the cord is shot.
Green light keeps flashing and head wont charge
Had this problem too
just remove the rubber cap where the charger bit is and replace the 2 RECHARGEABLE batteries. If the light is flashing just turn the power off on the headphones. :)
6helpful
2answers
Red light wont go off headset wont turn on
SImply connect the headphones to a power source. Then press up and down volume buttons at the same time. It will reset the headphones.
Free Pulse
The following procedure will re-establish the communication link between the Headphones and the Wireless adapter, this is called "pairing". Before you start please make sure both the headphones and the wireless adapter are fully charged and turned off.
Note: The headphones and the wireless adapter come pre-paired from the factory.
1. Press and hold the power button on the headphones. See Figure 1.
Figure 1
2. Continue to hold the button down until the LED starts flashing red/blue in an alternating pattern. Release the button when the LED starts flashing red/blue. See Figure 2.
Figure 2
3. Once the headphones LED is flashing red/blue, press and hold the power button on the wireless adapter. See Figure 3.
Figure 3
4. Hold down the button until the LED starts flashing red/blue in an alternating patter. The LED will blink blue, then turn off for a few seconds then blink red/blue. Release the button when the LED starts flashing red/blue. See Figure 4.
Figure 4
5. Once both the headphones LED and the adapter LED is blinking red/blue, press the volume up button once on the headphones. See Figure 5.
Figure 5
Once the headphones is paired with the adapter, the LED on the headphones will blink blue once every two seconds. See Figure 6.
Figure 6
When the adapter is paired the LED will be solid blue. See Figure 7.
Figure 7
The adapter may continue to blink red/blue for a few seconds even after the headphones LED starting blinking blue. This is normal; the adapter may take a few additional seconds before the LED turn solid blue.
Once the headphones and the adapter are paired, it is not necessary to pair them again even if the batteries on both units are completely drained.
Additional Note: Repeated pairing will not improve the sound quality or give the headphones and the adapter a cleaner connection.
Top Logitech Audio Players & Recorders Experts
Paul Bade
 Grubhead
Grubhead
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
