more than likely, the buzzing sound is probably the circ pump struggling. this is very common. first check filter is clear. if it is there is a hose from the circ pump to the top of the tub or to the door seal, make sure that isn't blocked. don't worry ab there not being much water in the machine, these machines don't use much.
inside the rubber O on motor that controls the door open and close got uncoiled it should look like a side ways 8 and have that twist on it took me forever but i figured out thats why my door wasnt closing not enough pressure on rubber belt to pully u need to just put that twist n it should work good luck!
Greetings! Did you ever find a replacement remote? I just bought a Slim-1400 at a thrift store but it lacks the remote. I've been searching for quite a while without any luck. If you had success, can you let me know at [email protected]?
It fixed itself; when I bought the unit (used) the rear lower panel was missing due to ham-handed movers. This part has the exhaust port. While inspecting the unit, I tipped it fowrard and backwards; the buzzing stopped when tipped fwd.
Once I installed the new part, whatever was causing the interference or harmonically upset.. all is good.
I DID receive the parts manual from a friendly parts department; I'll try to post that here somewhere.
with the unit turned off press memory once and the hour digits flash.
Press the cd ship |<< or >>| buttons to adjust the hour.
Press memory again and the minute digits flash
Press the cd ship |<< or >>| buttons to adjust the minutes
press memory once more. the display stops flashing and the clock has been set.
