SOURCE: No electric power generated from my Coleman Powermate Maxa 5000W.
the gensets on coleman generators are definately nothing to brag about but i would start by checking the windings and make sure the brushes have a clean armature to ride on
SOURCE: coleman powermate 6250 mod# PM0525303
The most common problem is the capacitors blowing. This is the round (usually white in colour) barrell shaped device usually found in the end cap of the alternator. It will have two wires attatched to two of four pins. I would advise that you check the voltage at the end of the alternator first to eliminate a wiring problem. The capacitor can only be tested with the correct equipment but changing it should solve your problem- 75% sure.
SOURCE: My coleman powermate generator will start but will not generate.
The voltage regulator controls the output. You will need to check that first.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
SOURCE: owners manual
Try this link. The model number will be on your endbell.
http://www.powermate.com/productmanuals.php?cat_id=3
SOURCE: I have a coleman powermate generator 6250 max
you must dislocate the handle and it's base ...you will find the magnetos in the FLY-WHEEL area.trace it's wireing till you find a cut-off black wire...and reconnect it...
PS. it might be disconnected and not cut...and that way it will be harder to trace..
if u have any further questions email me at [email protected]
