Master
- Posted on Jun 10, 2010
Re: How can i get itunes to download on my phillips...
Transfer music via Windows Media Player 10:
- Hook up your GoGear with the PC via the supplied USB cable.
- Make sure you connect your GoGear micro also to the main power supply.
- Launch the version of Windows Media Player 10.0 installed in your computer. Note: Once the device is connected to the computer, all playback or radio will stop.
- Check and make sure that the Create folder hierachy on device option is enabled in Windows Media Player. Go to Tools>Options. Select the Devices tab and then highlight GoGear Audio and click Properties
Click OK to close the windows.
- Click Sync.
- In the Items to Copy pane, in the drop-down list, click the playlist, category, or other item that you want to copy.
- Click the check boxes next to any files you want to copy.
- In the Items on Device pane, in the drop-down list, click to select PhilipsGoGear to copy files thow can i get itunes to download on my phillips - 051028091952_1760.gifmi">Click the Start Sync button.
- The Player verifies that there is sufficient storage space on the device to copy the selected files. If there is sufficient space, the files are converted (if necessary) and copied to the portable device.
- Repeat steps 2-5 for any other items that you want to copy to your portable device.
- Once the transfer is completed, close the Windows Media Player
- Unplug the GoGear from the PC and enjoy the music on your GoGear.
Transfer music via Windows Explorer:
Note! You cannot transfer pictures via Windows Explorer, for pictures use Windows Media Player.
- Connect your GoGear with the PC via the supplied USB cable. Make sure you connect your GoGear also to the main power supply.
- Launch Windows Explorer.
- Once transfer is complete unplug the GoGear from the PC and enjoy the music on the go.
