Question about Samsung LE40R73BD 40 in. HD-Ready LCD Television
Our TV does not turn on right away. It sounds like it is clicking on and off several times before it clicks on and stays on. It does not matter if we turn it on with the remote or at the set. The light ( blue eye) slowly gets brighter with each click. It will do it five, six, seven or more times before the sound of the TV is heard and the set comes on. The TV is workling great except for the initial turn on. The seems to occur only when the set is "cold". If it has been used in the last half hour, it will turn on right away with just the remote. We are worried that the on/off mechanism will wear out if this continues much longer. Please help.....
Posted by beckydetran on
5 Related Answers
marionbagget
  • 718 Answers
SOURCE: clicks on and off several times before staying on
The power supply will sense if the set is 'drawing' too much current and switch itself off. This could be the case here. The power supply board may eventually go completely bad.
Posted on Feb 23, 2009
Anonymous
  • 7 Answers
SOURCE: Samsung LN-5265F LCD TV is very slow to come on.
its the elecrolytic capaitors on the power supply.
goto www.earthinfo.org/samsung-tv-makes-a-strange-clicking-sound
it shows how to fix it yourself for only 'peanuts'
Posted on Aug 05, 2009
Anonymous
  • 6 Answers
SOURCE: samsung tv turn on problem
check here: http://www.earthinfo.org/samsung-tv-makes-a-strange-clicking-sound/ [worked for me]
Posted on Sep 01, 2009
Anonymous
  • 36 Answers
SOURCE: tv tries to come on but just clicks and clicks.
There are 3 capacitors in power supply board, all 1000uF10v.
2 for 5vdc and 1 for 12vdc. replace with best quality 1000uF 25V cap.
do it yourself repair will save you $300
Posted on Nov 16, 2009
protech309
  • 15 Answers
SOURCE: Samsung PN50A550 Plasma TV started clicking on
hi i have replaced power controls boards in more than a few of these & this needs to b done by a expert .
Posted on Apr 11, 2010
Testimonial: "I figured it would be something along that line-Here in AK, repairs can be costly-but I'll get a pro. Thanks!"
Philips Magnavox 32MT3305 keeps shutting off with relay clicking. The green power light stays on but the picture and sound go out right after the orange status bar goes away. If the channel up or down...
the relay is the safety protective device..sometimes a defective component or something. maybe an overloaded power supply might caused this problem..so before any thing could gets worst..the relay will shut the unit..
Jul 18, 2011 | Philips 32MT3305 TV
No picture on my philips 42PF7321D/37
Bad caps in the power supply must be replaced .
Jul 21, 2009 | Philips 42PF7320A 42 in. Plasma HDTV
TV turns off by itself
Thus the line connected to a surge protector or some kind of line protector. This can be consider.
Or if this is a crt type tv. This could be a fault on high voltage section. Horizontal output transistor or flyback. But check also for loose connection/solder crack. That clicking sound may be the relay in action.
hope i give some correct input.
Apr 23, 2009 | Samsung PCL5415R TV
Tv keeps turning itself off
This Sounds like you need to have the flyback replaced on the main board!
Dec 12, 2008 | Philips Magnavox DVD/VCR Dual Player
Clicking noise
The clicking noise is a protection circuit that prevents the TV from switching on when a fault is detected.
That means that there is a short, a bad solder joint, or a bad component inside the TV, usually any good technician is able to find out at least the nature of the fault. Often this jobs must be done at a repair shop, as testing may take time, probably your technician was just in a hurry.
All you can try at home is leaving tv unplugged for a couple of hours, this drains power from the set , and fix some problem.
If it does not work send it to a repair shop.
Dec 11, 2008 | Akai PT4298HD Rear Projection Television
Sony Wega kv27FV310 standby flashes 2 times with no picture or sound
3 years ago, i had the same problem with a samsung 36", when i switched it on it would stay on for around half an hour, i tried to switch on straight away, but it wouldnt, i had to leave it for an hour or so, then it would stay on for about 5 minutes. And the same thing the next day (half an hour then 5 minutes). I left it into the repair shop, it had to get a circuit board replaced at a cost of £315, dont know how much it will cost to get fixed now, as i could buy the same tv for a little over that now.
Apr 14, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
No picture just clicking sound
with your model number manny have a defective flyback part number is 1-453-310-11
regards,
daniel.
Mar 31, 2007 | Sony KV-27FV16 TV
TV solution
You may have a bad solder joint on the horizontal driver transformer or somewhere else in the set. I found this problem with this transformer several times. Stargazer
Samsung LE40R73BD 40 in. HD-Ready LCD Television Logo
294 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Todd Hill
Todd Hill
