Question about Dyson DC07 Animal Bagless Upright Cyclonic Vacuum
The belt is not turning the brush bar when in the carpet cleaning position
Posted by gordon_sm279 on
Samyfam
  • Dyson Master
  • 379 Answers
DC7s have two drivebelts that turn the brush bar - one connects the output of the motor to the clutch, the other connects the clutch to the brush bar.
You can check the latter simply by removing the sole plate and looking. Unfortunately the other beltthe belt is not turning the brush bar when in the - 2_bing.gif is hidden under a plastic cover, so you cant see if it is okay or not without some dismantling. This cover is not easy to remove and requires a Torx driver to under the securing screws.
If, after removing the cover, the other belt is okay, then you have a faulty clutch. New clutches are available onreasonably cheaply, but again good tools and DIY skills are required.
Have a look atwww.dysonmedic.comwhich has some excellent info on dismantling and repairing a DC 07, but unless you haveaccessto such tools, and feel confident to tackle it, it's probably time tocallDyson or aVacuumrepairer.
Posted on Jun 16, 2010
Brushes don't rotate on proheat2X,
How to Replace the Belt & Brushroll on Bissell ProHeat 2X ...
? 2:11
https://www.youtube.com/watch?v=Jj_43IHz9U4
Dec 28, 2012 - Uploaded by eVacuumBags
How to Replace the Belt & Brushroll on Bissell ProHeat 2X Series Carpet ... How to Replace Bissell Deep Cleaner Pump Belt orBrush Belt - Duration: 1:44. ... Won't SPRAY solution Rollers spin Fixing Bissell ProHeat Carpet ...
Brushes Will Not Rotate Deep Clean Essential - YouTube
? 0:53
https://www.youtube.com/watch?v=gbEXY5jkWSc
Apr 9, 2015 - Uploaded by BISSELL
If your machine is turned on and in the upright position yourbrushes will not turn. ... How to Replace the Belt & Brushroll on Bissell ProHeat 2X Series Carpet ... Won't SPRAY solution Rollers spin Fixing Bissell ProHeat Carpet ...
bissell pro heat 2x brushes wont spin Questions & Answers ...
www.fixya.com > Forum > Tags
... bissell pro heat pet 2x and my brushes won't turn or operate... check the belt belts ok brushes won't turn/rotate turn dial on bottom front on the water tank to ...
Feb 03, 2016 | Vacuums
Why does Beater Bar Fail to turn
Per owner's manual
1. Make sure the brush control is set on carpet mode.
2. The brush will only spin when the handle is reclined.
Others:
The belt has worn out and needs replaced. Although it appears okay, stretching is possible, which would result in too loose a grip to turn the bar.
If the belt was replaced, it may not have been pulled tight enough to turn the bar. To tighten on many vacuums, simply loosen the screws on each end of the brush, pull toward the front of the power head and hold while tightening the screws.
Jul 25, 2014 | Dyson DC14 All Floors Upright Vacuum...
Dyson dc33 brush won't turn but belt not broken
Hi there, it's Jack at Dyson.
DC33 is suitable for cleaning hard and carpeted floors. It includes a brush control system which allows you to shut the brush bar off when cleaning hard floor surfaces. It's worth checking that the brush control is set correctly - it's possible it may have been inadvertently set to 'Hard floors'. For the brush bar to rotate, it must be set to 'Carpets':
It's also important to note that the brush bar will not rotate when the vacuum is standing upright, so make sure you recline it into the normal vacuuming position before testing it.
If this doesn't resolve the issue, please turn off and unplug the machine, then check that there are no obstructions in the cleaner head which could be jamming the brush bar. Remove any threads or hair around the brush bar, as these can affect the performance.
If you'd like further advice from our experts after you've given this a try, please call us on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU). We can take you through some diagnostic checks to determine what may be causing the issue. If a repair or replacement part is needed, we can also confirm if this is covered under warranty.
Jun 05, 2014 | Dyson DC33 Bagged Upright Vacuum
Brush roll won't turn only a few times
Shane:
Unplug the machine and lay it on it's back with the handle release in the release position (the vacuum head should be laying flat also). Remove the foot plate from the vacuum head. Manually turn the brush roll (called a beater bar). The beater bar should turn fairly easily and the belt should turn the motor armature shaft (now would be a good time to check the inside surface of the belt for grooves or damaged spots which would cause the armature shaft to slip on the belt). If the beater bar has too much resistance to your turning it, I would suspect that the bearings at each end of the beater bar are fouled with hair, carpet fibers and string. Remove the beater bar from the machine and manually spin the motor armature shaft (where the belt contacts the motor) to see that the motor armature shaft spins freely. Remove the bearings from the end of the beater bar (they won't come off easily so you may have to use a prying tool such as a screwdriver). Try to spin the bearings. If they are fouled, dribble some rubbing alcohol into the bearing (I use a spray bottle... it's much neater) and turn the bearings while keeping them soaked with alcohol until they spin freely without ratcheting. Drop some 30 weight engine oil into the bearings until they are saturated, then clean the outsides of the bearings with a clean rag (no alcohol) until the outsides of the bearings are completely dry and no oil drips out of them (don't want the oil to attract dirt). You'll probably need to replace the belt. Reassemble the machine and it should work for you.
Jun 07, 2013 | Oreck UPRO14T - Vacuum Upright Commercial...
Brush bar not spinning when set to high or low on carpet
1) adjust the belt, see for broken or worn, and replace
2)see for brushroller obstruction, and clean it and repair
3) see if the brushroller without belt run smooth, otherwise repair and fix it.Lubricate.
4)See if the motor run without load( NOT belt+brushroller) very well. in negative case repair motor.
God bless you
Jul 15, 2012 | Vacuums
Ratchet noise, beater will not turn, belt not broken, in carpet mode the Dyson d07 makes huge ratchet noise and the belt will not turn the beater brush.
Ok, so I had the same ratching noise and took the advice of many sites directing me to clean the brush. But like most I cleaned the brush and the noise continues and the brush does not spin. Reluctant to take it to get serviced I dug a little deeper and now it works just fine. This is what you need to do as removing any hair from just the brush part will not be enough.
Remove the entire brush bar from the bottom of the Dyson, this means pulling the bar out of the drive belt. This is not to difficult just use a little muscle as the belt will stretch. Once the bar is out grasp hold of the two plastic end caps on the brush bar which the brush bar actual spins in. These two caps are connected by a slim metal rod which runs through the brush bar. Place one hand on each side and begin to twist and pull until one of the caps comes off. Once the cap is off of the one side you can pull the other cap from the other side through the brush bar as this cap will be the one attached to the slim bar I mentioned above. If like mine you will see a ton of hair wrapped around these caps and inside the ends of the brush bar. Clean them out as best as possible.
After you clean it out, run the cap with the rod back through the brush bar, attach the other cap and twist and push together. Make sure the caps lineup which each other just like they were when you pulled it out. You'll notice how much more freely the brush bar spins between the two caps then before you cleaned it. Now, pull on the drive belt and feed the brush bar back through and attach as it was to begin with. This did the trick for me.
Apr 25, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Belt wont turn makes a loud noise when put on carpet setting
If this is a Dyson with a protected belt that can't be replaced then it will have to be sent out to Dyson or get a Dyson servicepersonnel to check it over - protected belt motors are difficult to fix by yourself. If its clicking all the time, then it means the belt has to be replaced. In the mean time check that there are no obstructions on the beater bar and behind it and also check that the brush stop roller at the top of the hood is in the right position. It should move automatically when the handle is swung down in normal operation.
Feb 23, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Correct position of beater bar on a Dyson DC14?
I had the same problem. I removed the brush from the machine. The brush should move freely when removed. If it doesn't move freely, pull the ends from the brush, both ends come off(one will have a rod fixed to it). I would suggest you clean the ends and the inside of where the ends sit on the brush. I applied a little grease on both end housings(inside end housing) if no grease available try washing up liquid. Put the brush ends back on the brush. I then spun the brush to check that it moved freely. It should move freely, if it does fit it back on the machine and it should be silent. If you cant get it to move freely I suggest a replacement brush. Tip: I used a blunt knife and placed it through the belt to avoid removal of the belt. Good luck. Cheers Jason
Jan 19, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
Brush Roll belt won't engage on WindTunnel self-propelled
When you had the brush roll off, did the ends turn freely? If not then the brush won't turn and the belt will just slip. You would have to replace the brush roll if either of the ends are frozen. Other then that you would have to remove the top cover to see if there any broken parts, there is a spring loaded asm, it has a black wheel that will push the V belt when it is in the carpet setting and the handle is in the down position, it could be jammed so the roller is stuck.
Jul 16, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
DC 07 BRUSH BAR DOES NOT TURN BELT OK
Stand vacuum up and with it plugged in. Rotate knob between carpet and bare floor and back 5 times leaving it on carpet when finished. Rotate vacuum back from upright position and lay vacuum on the floor, rotating it onto its side. Turn vacuum on.
Jun 16, 2007 | Dyson DC07 Animal Bagless Upright Cyclonic...
Dyson DC07 Animal Bagless Upright Cyclonic Vacuum Logo
339 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Mike
xxxxxx xxx
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
