First remove the plastic 2 piece shroud around steering column so as to gain access to the housing the tumbler sits in. Find three Phillips screws to remove in holes in the lower piece.
Turn the ignition key to the Run position. Insert a small tip screwdriver in the access hole on the bottom of the housing to push the spring-loaded tab which will free the tumbler so you can simply pull the tumbler out with the key.
Installation is the reverse. Be sure tumbler with key inserted is set to the Run position.
Depress spring-loaded tab, insert tumbler into housing hole with tab down. All the way in,
Turn key to the Lock or turn it off.
Let us know if you want something more else please accept the suggestion.
Thank You for contacting Fixya.com
Testimonial: "Clear instructions."
