Note the level do go up and down but very low output.
Please disconnect your speaker and using a good 1.5 AA cell test for a good response. if Ok connect to the amp and power. Hope you are using the right source input. If not give you input to another source input and check. If not it is important to check with a signal test for the failed section. Attempt this only if you are familiar or else ask a friend to test from the output backwards to find the section which is not responding and attentuating. It sould be a possible failure in the premap/ input selection or a biasing of these circuits. Hope this helps. Good day
