Samsung SyncMaster 710N 17" LCD Monitor Logo
Posted on Jun 10, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Samsung Syncmaster 710N PROBLEM !!!
I bought my Samsung Syncmaster 710N 5 years ago, till here it worked fine, but now the screen doesen't work. If i turn on the computer the screen works fine for 2 seconds and then turns off but the green light is still on, when i press the screens power button off and on the same thing happens again.
Please help .
K
Bud Martin
Level 3:
  • Master 11,361 Answers
  • Posted on Jun 10, 2010
Bud Martin
Master
Level 3:
Answers
11361
Questions
Helped
3368332
Points
33650
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, poor solder jopints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
My syncmaster 710n is not working. I get the box where it ses what resolution si the right one, but the syncmaster 710v works normaly. Does that means my 710n can`t be repared anymore? Thanks
Not completely sure what you're saying. Here's what I got out of your problem:
You have a Syncmaster 710n that displays a box saying the best resolution is _____ x _____, but your Syncmaster 710v doesn't show that message.
The main question I have to ask you is whether or not you see the screen or display behind the message on the Syncmaster 710n.
In either case, I doubt that this is a hardware problem. I also highly doubt that your monitor cannot be repaired. Try the following:
1) If you see the display/screen is showing behind the message box, this is almost definitely a setting issue. You need to press the menu button on your monitor and look for an option that says something like "display resolution message" or "ideal resolution message", or something else like that. Then you need to change the setting for that option, for example if "Yes" is selected, then you need to change it to "No" or if "Enable" is selected you need to change it to "Disable".
If you have the manual for the monitor, it should make it easier to know what setting to change. If not then go here:
http://www.samsung.com/us/support/detail/supportPrdDetail.do?menu=SP01&prd_ia_cd=05020100&prd_mdl_cd=&prd_mdl_name=710N&prd_ia_sub_class_cd=P
and download the Manual that you need.
2) If nothing is being displayed behind the message, try to change the display settings of your computer. While using a different monitor, try the following: If in XP, right-click on the desktop and go to Properties, and select the tab for display settings and adjust the resolution to something compatible with your monitor (like the one it suggests you to change it to). If in Vista/7, right-click the desktop and select Screen Resolution/Display Settings and adjust it there.
Good luck. Let us know how it goes.
1helpful
My monitor screen just went white.
ejones999, Could be toast. if under 3yr old, contact samsung and see if they will do swapout for you. Did you connect working monitor to the port where the bad unit was to PROVE 710N is really bad? Tech type person will need to evaluate unit to see if it is a viable candidate for possible REFURBISHING. You failed to state age of unit and /or # of total "ON" hours unit may have. I'm louie12fix on fixya or lmistyrel on aol .com Bye for now.
I have the syncmaster 710N. I recently had a
hi
I am a technician-informatic. I have repaired about 60 Lcd Samsung monitors with thees problems - not optimal resolution mode and dark screen problem. So i decided to made manual how to repair lcd samsung monitors.The repair process is very simple 10-30min. does not need a lot of experience in electronics and expensive instruments.
if you are interested check it on eBay.
Samsung monitor repair manual guide 710n,913v,510n more
or just enter number in search field: 220409788372
thank you
I have 2 samsung 710N LCD monitors that are exhibiting the same symptoms. When they are powered on, they display fine for about 10 seconds, and then go completely black. If you turn them on and off again,...
hi
I am a technician-informatic. I have repaired about 40 Lcd Samsung monitors with thees problems - not optimal resolution mode and dark screen problem. So i decided to made manual how to repair lcd samsung monitors.The repair process is very simple 10-30min. does not need a lot of experience in electronics and expensive instruments.
thank you
2answers
Samsung 17" Flat Panel Monitor - Streaks
I had this same problem with my ViewSonic LCD monitor. I tried turning the monitor off from the button on the front, and tried changing the settings for the monitor. That didn't help. But then I unplugged it from the power source, and the streaks immediately vanished!
Samsung SyncMaster 710N 17 in. Flat
hi
thank you
Syncmaster 710N resolution problem
no,
the LCD display don't harm the eyes cause don't spreed radiation.
preferred resolution 1280x1024 at refresh rate of 60Hz is not optimal.
the samsung 710N can easy handle 75Hz at 1280x1024 so just change it.
Top Samsung Computers & Internet Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Jean Thiebaux
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
