Question about Jandy Aqualink Rs4 One Touch Control System Control System
My spa light is assigned to aux2. recently it does not turn on. how can i check it to see if this is programming problem or it is bulb burn out problem? please reply to [email protected]
Posted by alir899 on
Ian Kime
    Habit-Forming:
  • 77 Answers
You'll have to check the bulb to see whether or not it's blown, unless you have a multimeter so that you can check the output from the PCB.
Regards,
Ian.
http:hottub.synthasite.com
Posted on Jun 18, 2010
My pool light is an old Hayward 300 watt 12 volt light bulb. I recently replaced the transformer and had a pool company replace the wire and bulb holder. Worked fine for several months until burn out.
I have the same one an it last about ten years.In 45years I replaced in only 4 times.They might have two much voltage to the light or water leaking in
Apr 01, 2018 | Pool & Spa
Auxbeam led bulbs burning out
Wear gloves when changing the bulbs. Your body oils will cause the bulbs to burn extremely hot and burn out. Check your tail lights. Some vehicle's interior light goes out of stays on when your tail lights malfunction.
Aug 21, 2017 | Cars & Trucks
RS4 aux3 and aux4 pulse relay instead of solid voltage.
You or some one else may have assigned the AUX 3,4 to "dimmer" in system settings. Check the setting and make sure it is not set for color lights as well.
Jul 16, 2016 | Jandy Aqualink Rs4 One Touch Control...
Need code for apex tv/dvd combo to program remote
http://www.hifi-remote.com/ofa/apex_help.shtml
To program the Apex DVD player on your Radio Shack or One For All remote, there are several steps involved. Basically you will be using the TV device code 0030 and re-mapping all the buttons. There's several steps to get wrong so I will include lots of error checking so that if you make a mistake you will know where you went wrong. Before you start, you should print off the advanced codes.PLEASE NOTE:This will only work for the AD600A model. There isn't a code in any of the current OFA/RS remotes for the newer models (ie, AD500A, AD660A, AD703A, AD800A, etc)
1. Confirm that you have TV code 0030 on your remote.
(Every remote has this code, I am including this step just for your piece of mind, by all means skip it and come back to it if you have problems).
a. Turn on your DVD player and have is displaying on the TV.
b. Press the TV button.
c. Press and hold the SETUP button (the green P button on R/S remotes), wait for two flashes.
d. Type 0030 and wait for two flashes.
e. Press the POWER button, you should see the VOLUME indicator display on the TV screen.
You have now confirmed that you have the TV code 0030.
2. Re-assign the DVD button.
(On the Cinema 7 remote you will probably want to use the DVD button, on the R/S remotes you might want to chose the AUX2 button. In this example when I refer to the DVD button, I am referring to whichever device key you have selected to control your DVD player).
a. Press and hold the SETUP button, wait for the two flashes.
b. Type 992, wait for the two flashes.
c. Press the TV button, followed by the DVD (or AUX2) button. Two flashes.
You have now re-assigned your DVD button to be a TV button, this is so we can enter the TV device code.
3. Assign the TV/0030 code.
a. Press the DVD (or AUX2) button.
b. Press and hold the SETUP button, wait for two flashes.
c. Type 0030 and wait for two flashes.
You have programmed the DVD button to TV code 0030.
4. Program the function buttons.
(You will have to program every button that you intend to use. Don't waste memory by coding buttons that you will rarely, if ever, actually use. If you don't think you will use the numeric keys, for example, don't program them. If you intend to use the volume controls from your TV or amplifier, don't program the volume controls).
I will walk you though setting the POWER button.
c. Type 994, wait for the two flashes.
d. Press and release the SETUP button. (Don't hold it this time).
e. Type 052 (this is the code for POWER).
f. Press the POWER button, wait for the two flashes.
g. Press the POWER button, your DVD player should turn off.
You have now programmed the POWER button. Repeat the steps above for all the buttons that you want to program.
5. Resetting the DVD device.
In order for "volume punch through" to work, you will need to reset the DVD device button to be a DVD button again. This is only an issue for the Cinema 7, because "volume punch through" only works on the original VCR and CBL buttons on the 15-1994, and even then it will only work with the TV's volume).
c. Press the DVD button twice. Two flashes.
You have now reset the DVD button.
6. Setting up the volume controls.
You have several choices with the volume controls. You can program them with the APEX codes, which will invoke the DVD players volume controls, you can use "volume punch through", or you can manually set the volume controls to operate the device of your choice. In this example I will assume that you want to use your stereo equipments volume controls and that the stereo is programmed to the CD device button. Please replace the CD button with the TV button in this example if you want to use your TV's volume.
d. Press the CD button, followed by two presses of the VOL UP button.
e. Wait for two flashes.
You have now programmed the DVD's volume up button to control the CD's volume up function. Repeat these steps for the volume down and mute buttons.
7. Setting up a Loophole Menu macro button.
If you have the version of the Apex that has the "Loopholes Menu", then you might want to set up a button to take you right there. It saves having to remember the secret steps. In this example I am going to put the macro on the "S4" button, but you can put it on any button you like, just remember that it will be in effect under all devices.
c. Type 995, wait for the two flashes.
d. Press the S4 button (or the button of your choice).
e. Press the following buttons in this order (the button names in paranthesis are the buttons that I suggested these Apex functions be assigned to):
STOP, STOP, SETUP (Program), STEP (Move), PREV TRK (CH Down), NEXT TRK (CH Up)
f. Press and hold the SETUP button, wait for two flashes.
It is important to hold the SETUP key until you see the two flashes in the last step. If you release it too soon, the remote will assume that you want the SETUP button to be part of the macro, which will cause some un-expected results when you try using the macro.
Hopefully you have now successfully programmed your remote to handle your Apex DVD player, now you can enjoy movies from all over the world. if you haven't already visited the un-official Apex head quarters, here's the address: www.nerd-out.com/apex.
May 15, 2015 | RCA Universal Remote Control
Need tv code to program remote
May 15, 2015 | Apex Digital Televison & Video
Ford f150 truck flasher relay
I doubt it is the flasher since it handles both sides. A more likely cause is a faulty bulb socket or wiring problem.
Jan 23, 2014 | Cars & Trucks
I recently replaced the front rotors, brake pads and master cylinder in my 2003 Durango. I've since discovered that the brake lights are not working, including the 3rd brake light in the tailgate. I...
Hello, Well there is not much more it could be unless you have a shorted wire or a burned fuse. I would normally think that the turn signal canceler was bad but the 3rd brake light will still work if that is bad so I would check all fuses and for bare or shorted wires.
Jan 18, 2011 | 2003 Dodge Durango
My left side blinkers won't work,when you turn them on the security status lamp comes on and stays on until you turn the ignition off. I have checked the fuses and bulbs and both are ok. I have also went...
Either one of your bulbs is faulty or burned out, or the socket is rusty. remove the lenses on both lights, remove the bulbs and check them closely. replace with identical bulbs, and use a pencil eraser to clean the contacts, both on the bulbs and in the sockets.
Mar 25, 2010 | 2005 Harley Davidson FLSTN- FLSTNI Softail...
Jandy Aqualink Rs4 One Touch Control System Control System Logo
112 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
rogerpaul3
Level 1 Expert
Marvin
Marvin
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
