Thats not a good idea because you are running too many speakers off that amp it it could possibly blow a channel or the whole amp. trust me i've done it
It is possible, just as long as you maintain the resistance within the acceptable ranges, and so long as the speakers are able to handle the power. Also, make sure that both channels have the same number of speakers and resistance on each channel. You should be safe that way.
I've had a few people hook up multiple speakers up to the same amp, and basically you could hook up an indefinite number of speakers to one amp, so long as the resistance remains in that range. However, you will loose power to each individual speaker, and therefore, your system will start to loose volume with each added speaker.
The different style of circuits you can use are parallel and series circuits, the resistance formulas for each can be found easily online. Just ensure that each circuit is properly attached and calculated, and you should have a nice amplified system.
Again, in order to not fry the amp, ensure that both channels have the same resistance, and that they are within the appropriate ranges.
