A E005 means that the cleaning web for the fixing rollers have run out & there is also a counter that needs to be reset. There are two cleaning webs in the fuser unit there is a upper & lower web. They are white. The copier was calling for replace the web before it coded out. They clean the rollers off & oil's the rollers so the toner will not stick. You may find the parts on line, they are a bit tricky to replace.. Good Luck
Testimonial: "Thank you very much. I'll try to find the parts on line."
Have a nice day and do not forget to rate please...!
