Garmin nuvi 205W GPS Receiver Logo
Posted on Jun 09, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Word spacing if want the city new bruswick how do you space the to words
Jeremy Kuipers
Level 2:
Scholar:
  • Expert 106 Answers
  • Posted on Jun 09, 2010
Jeremy Kuipers
Expert
Level 2:
Scholar:
Answers
106
Questions
Helped
68831
Points
320
First off New Brunswick is not a city, It's a province. Second the two main cities in it are Moncton and Fredericton. However there are more.
Check THIS out.
How do I adjust the spacing between sentence and between paragraphs?
It depends on which program you are using. In Microsoft Word, to change the space between all lines in a paragraph, click the Home tab. Then in the Paragraph group, click the Line Spacing button. A popup menu should appear. Select your new line spacing value. The line spacing is set for the current paragraph or all highlighted paragraphs.
2answers
When I hit "Enter" it always double spaces. What do I need to do to get single space?
Your word default is set to double space. You need to find your paragraph setting, depending on the version of Microsoft Office you are using. Once you find the paragraph settings, you need to set it to single spacing and set the "spacing before" and "spacing after" to zero as in the attached picture.
One way to set the option is to hit control-A to highlight the whole document and then right click, and then click on Paragraph.
25547294-44porhhyjuxju0hkakw43rbb-4-0.jpg Good luck.
Paul
1helpful
Double spacing
Before doing anything else, highlight all the text (including any 'white space' that might follow), that you want to change into 'single' spacing. Then go to top menu 'Format' then select 'Paragraph' and on the new menu find 'Spacing', Then on the pull down menu select 'single' and 'OK'
I live in a small apartment in New York City and don't have a lot of space for a wine cooler. Can anyone suggest a good cooling system for my situation?
You should get a countertop cooling fridge. They are very compact, about the same size as a microwave oven, and can hold up to 20 bottles of wine.
Jul 31, 2012 • Furniture
1helpful
What's your problem?How to change line settings on new document
See the picture.
the button circled in red is for line spacing settings.
Click the button and select line spacing.
If you want to set paragraph formatting options (like in Word 2003), click the small arrow icon right to the word 'Paragraph' below the line spacing button.
I bought the game Bruswick bowling and when i put the disk in . it ask, do i want to upgrade ,but i cannot make the curser to go to yes
Try using your keyboard to select the option. Use things such as the arrow keys, tab key, space bar, and pressing the Y, N, or enter key. Also, try pressing shift+tab while in game and going back to the game window by using that. Hopefully, your cursor should be available.
Usuall i i leave 1 space between 2 words, but if by mistake if two or more spaces are entered how do i detect them.
You don't mention which program(s) you are using.
The easy answer is to use a decent word processor such as Microsoft Word. This will have auto formatting rules that cater for things such as double spaces that aren't after a full stop.
Where that doesn't work, many programs have a Find and Replace option. Use this and type two spaces in the find box and one space in the replace box. Go through replacing each one manually as you want, or hit Replace All. Try using CTRL+F to access this option. This works on OpenOffice.org Writer (a free alternative to Microsoft Word - you can obtain it from www.openoffice.org if you do not have Word). Word should be the same - CTRL+F to open Find, then depending on version it will have a Replace tab. If not, look on the Edit menu for Find and Replace. In Notepad, there is a Replace option on the Edit menu (CTRL+H).
City Navigator Lower 48 States NT 2009
Hello parteeboy24,
The on board memory in your Nuvi 200 may not have enough free space to hold the map. You may be able to free up some space by deleting maps or language packs that you don't use. (Be careful to back up any files you are going to delete.) Or you can add an optional SD memory card to the unit to increase the storage capacity on the GPS.
Best Regards,
Ken
"Go Ahead. Use Us."
Top Garmin GPS Experts
vince
Jesse Walters
Jesse Walters
Are you a Garmin GPS Expert? Answer questions, earn points and help others
