Aiwa AV-D67 Receiver Logo
Posted on Jun 09, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Dear Friends, I have this Audio system (tuner,twin
Dear Friends, I have this Audio system (tuner,twin tape recorder,cd, video-all in one) gifted to me by friend. I don't have the operating manual. I am able to operate tuner, cd & Video, but not the Tape. I am unable to play my tapes and also unable to record. The sysytem is different from other systems (in operating buttons for tape recorder). Please help me to operate the tapes part in my system Thanks Giri
Anonymous
Level 3:
  • Master 8,546 Answers
  • Posted on Jun 10, 2010
Anonymous
Master
Level 3:
Answers
8546
Questions
Helped
2766159
Points
24828
Get the manual for free at retrevo.com
My Sony MHC-LX10000 when trying to switch to CD, tape, tv, or video it just goes right back to tuner/band?
Question edited for clarity.
There is a small battery on the mainboard that makes it keep its memory. Yours has failed or become depleted.
Google
make model service manual
Why cant I record FM from this Pioneer vsx921
To record from the built-in FM-tuner, you can use either the DVR/BDR or the CD-R/TAPE outputs of the receiver.
How to record a cassette tape to a cd
Your question is posted under a "CD Shelf System" heading. If you really have one of these, the answer is "you can't". The CD player is a player only, not a recorder.
On the other hand, if what you're asking is how to transfer cassette tapes to CD using a computer, there are a couple of ways. One is to connect a cassette player (boom box, component system cassette deck, etc.) to the line-in jack of your computer's sound card. Download and install Audacity, which is free software for recording and editing sound. Then you can record the sound from your cassettes as you play them into the computer.
Another option, If you want to be fancy and spend a little money, is to buy a USB cassette deck. It automatically converts the cassette audio to digital and sends it to your computer over a USB cable. Recording software is supplied (sometimes the Audacity program mentioned before). Several companies make them. Here's one from a company called ION that some friends of mine have, and it seems to work well for them. They've been converting a lot of tapes of family members, and Audacity has been good for cleaning up tape hiss and enhancing the sound.
Either way, once you have the sound in your computer and processed to your liking, you just need to burn it to a CD using whatever burning software you have. (I use CDBurnerXP. It's free, easy to use, and does everything needed for normal CD and DVD burning.)
MODEL GX250. CD PLAYER DOES NOT WORK. SYSTEM WAS IN STAND-BY MODE FOR SOME YEARS. TUNER AND TAPE PLAYERS WORK FINE. QUICK SOLUTION PLEASE.
This should be because you have not used the player for many years. Does the system eject the CD tray? Use the CD head cleaner CD that removes dust on the laser head if any. Try using the audio CD which are recorded in .cda format and not ion MP3 format.
1helpful
I have just been given a Hitachi ax-m68 amplifier.. can it only be used with the other seperates it comes with such as the cd and tuner, or can i use it for decks and a mixer somehow? I dont have the cd...
to use it with either decks or a mixer check to see if it has record out and play in ("REC OUT"/"PLAY IN") for tape 1 or tape 2 if so you can use a mixer connected there. If no tape inputs or record out you could only use the CD ("tuner" is a internal selection not an input selection) as play back connections.
Post back if you have more questions
How may i hook the phillips dvdr3455h/37 to record from my fm tuner,i have it hooked up as follows audio out on philips to tape in on amp and audio in on phillips to tape out on amp,but when i press any of...
The dvd recorder uses the video signal to detect, thus it will not detect the audio as a signal. I believe there are "boxes" you link in somehow to "fool" the dvd into thinking it's recieving a video signal, but I don't know where to get them.
2helpful
2answers
I cant find the operators manual for Panasonic audio rack system
 http://service.us.panasonic.com/operman/findmanual.aspx?cat=AUD
This link is for multiple Panasonic sound devices.  I am not sure whether your models are on here, but have a look.
1helpful
Having a hard time connecting various audio components
Yes, it is a little tricky...
1) CD Changer (output) -> CD input on Amp
this is tricky... this will allow you to record to your tape deck, and control the sound via the EQ:
2) Tape Deck (tape out / recout) -> TAPE PLAYBACK on EQ
3) Tape RecOut on EQ -> Tape 1 Playback on Amp
4) Amp Tape 1 RecOut -> Tape Deck Playback / Input / RecIn
in essence, your creating a loop starting from the tape deck, going to the eq, then to the amp, then back to the tape deck to record.
Your EQ has another set of LINE IN and LINE OUT - use the second Tape 2 on the amp to create another loop. This will
allow you to control the EQ for any of the other sources.
5) LINE IN on EQ -> Tape 2 RecOut
6) Tape 2 Playback on Amp -> LINE OUT on EQ
5) Radio Tuner (output) -> Tuner input on Amp
6) DVD/VCR Combo Output -> AV/AUX on Amp
7) PC Computer... you don't have room for this. You can either use the PHONO input, and you'll have to purchase a Line Level Phono Converter
or, get a Y cable and split the signal and share with some other source.
Hope this helps.
- OPTiC
www.djproaudio.com
www.repairny.com
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Mohammad Abumuailek
Mohammad Abumuailek
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
