Question about Whirlpool RCS3014 Electric Cooktop
Broke off switch, how to lift up or how to get to the broken off switch
Posted by flotin4 on
Anonymous
  • 31 Answers
The electric elements should unplug from their electric connectors. remove the knobs. see if the control panel lifts off, or screws off. after removing all of these things maybe you can tell how to get to the screws or how to remove the top of your cooktop.
Posted on Jun 22, 2010
Whirlpool stove knob shaft broke
you will have to replace the entire switch as the shaft is not available separately.
Oct 17, 2014 | Whirlpool Whirpool 5.3cf Self Clean Elec...
HOW DO I CHANGE THE BURNER SWITCH ON MY RA524
Unplug unit. Remove knobs, if they interfere with lifting the stove top. Lift stove top from front of oven, proceed to inspect dials for damage. Repair or replace as needed.
Aug 22, 2014 | General Electric Cooktops
I have a cook n vent system that comes up when you push a button. The button broke off and it won't go down
Buy a new switch and install it or have someone replace it! Maybe relocate the button so it won't be in the way and get broken again!
Jan 25, 2010 | Five Star TTN036 Gas Cooktop
Glass top broken need new one
Call Reliable Parts 1-800-666-0313 with your model number and they will ship you one. Good Luck, Appliance Specialists
Dec 30, 2009 | KitchenAid Cooktops
My husband was trying to help clean the controls and broke off the part that holds the control on the cooktop. Can it be replaced? Help . . . need all four burners for Thanksgiving! DCS CT304
You will have to replace the switch if he broke the shaft the knob was on. you can replace the burners just take the burner to your local parts store and show them what you need. on the switch you will need your model number.
Oct 31, 2009 | Cooktops
Broken selector switch
TURN OFF CIRCUIT BREAKER. Lift out cooktop, remove all machine screws holding the glass frame. Remove plastic knobs and lift glass top straight up. Make sure rubber gromits are not ripped or torn. Unscrew the small screws on the selector switch and then lift up and tilt over the small aluminum chasis holding the switches to expose the wiring connections. Pull off the wires and pull out the defective switch. Replacre switch, connect wires, re-seat switch chasis, and secure switch with screws. Carefully drop in the glasstop lining up the switch shafts and the rubber grommets. Secure the top with machine screws and drop back in the cutout.
Apr 18, 2009 | GE 30 in. Profile JP350 Electric Cooktop
Ceramic Glass broken
when ordering you would have to know the color also
Dec 05, 2008 | GE 30 in. JP340 Electric Cooktop
Cooktop fan switch replacement
1. Turn off the power at the breaker box.
2. lift off the air grill.
3. remove the two screws at the front of the control switch panel (escutcheon)..
4. slide the control panel forward until it disengages, then lift up to expose the switch assembly and wiring.
Jun 14, 2008 | Jenn-Air JED8230 Electric Cooktop
Cooktop downdraft blower control knob broke off
Hello
Yes their is a way, you need to unplug the power, and look for the brackes that holds the cooktop to the counter, remove those scrwes and lift the cook top, then look under the top lip and you will see small scrwes, remove those and the glass will lift, then just reverse the steps.
Hope this help!!
Eddie Rentas
Tupper Lake NY
Jun 08, 2008 | Cooktops
Not igniting
Probably broken switch. or perhaps broken ignitor circuit. If only one burner is broken is then it is switch. if they all don't work check the ignigitor circuit.
Dec 16, 2007 | GE 30 in. JGP326 Gas Cooktop
Whirlpool RCS3014 Electric Cooktop Logo
144 people viewed this question
Top Whirlpool Cooktops Experts
Michael Thomas
Michael Thomas
Gustavo Ortiz
Gustavo Ortiz
Are you a Whirlpool Cooktop Expert? Answer questions, earn points and help others
