Based on the number of issues on this website with the refigeration coils, this LG model is a piece of junk. I have the exact same problem as described by several people on this website. Is there any recourse we can take against LG ?
I found the same thing. I've had my LHD45EL for 2 or 3 years. Worked great for my basement. This year I hear it run, but it doesn't collect water. I cleaned the filter and of course nothing. I took the back cover off, and tried running it. The condenser runs, but the copper tube leading up to the coil doesn't get cold. My guess is that the freon (or whatever refrigerant they are using) has leaked out. There doesn't appear to be any way to recharge it, the original tube has been crimped and soldered. Looks like junking it and buying a new one is the only option unless someone is good with a torch and solder. My question is whether to go LG or not.
I also have this LG dehumidifier. It was in for repairs two years ago, (fan motor) but now it just stopped working (Jun 2010). It appears it is not getting any power, although the outlet works fine.I have cleaned the filter and let the unit defrost, but no change . Is there an internal fuse or something that is replacaeable?
If not I guess I will chalk it up to "outlived it normal service life" after 5 years ...
Did you clean the filter? remove cover on it and i think you will find its very dirty, clean with a dry toothbrush
There
are many reasons why a dehumidifier will not work or collect water.
Here
is a tip that I wrote to help people to figure out what is going
wrong with their dehumidifier
Dehumidifier
is running but no water is in bucket
heatman101
