Epson Stylus Pro 9800 InkJet Printer Logo
Posted on Jun 09, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Error req 0001002d
All the indicator lamp red and flasing
Anonymous
Level 3:
President:
  • Master 1,382 Answers
  • Posted on Jun 09, 2010
Anonymous
Master
Level 3:
President:
Answers
1382
Questions
0
Helped
552309
Points
5097
The only fix for this problem is you have to call Epson and state them that you are facing this problem. They will provide you the codes to unlock this error. Its a universal solution that only Epson can provide you these unlock codes and you cant find in any websites.So contact them and get your problem fixed soon.
Thank you !!
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Oct 22, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1374
Points
Hi im already changed new cleanig unit
PRINTER SHOWING 'SERVICE REQ E300'
Sadly this is a serious error requiring a replacement Laser Unit - if you are lucky. It may also be a system board error that is falsely reporting the error.
This printer is likely to be beyond economical repair.
Replace the 2 bulbs. Unit powered up correctly and turned on like normal. Then Lamp1 and Lamp 2 indicator lights blinked (Indicating Start UP). After some period of time, it switched to Red 6 times blink...
1 red blink every 2.5 seconds indicates a cover error-- for this check the lamp cover
2 times red blinks very 2 seconds indicates temperature error. for this let the projector cool off check filters and fans that there is no blockage of air for proper cool down
3 red blinks every every 2 seconds Power error. incorrect voltage input or internal malfunction.
4 red blinks every 2 seconds indicates Fan Error check the fans make sure they are working and not blocked or need replacing.
i have nothing on 6 ligths go ahead reconect and check for proper count. hope this information helps.
Best of Luck.
Ray.
Error code 0001002D is displayed and can not clear
Thank you for the inquiry.
This usually is a Epson Large Format printer error. You will need to replace parts to clear.
blank.gif headerline.jpg header.jpg epson_loyality.gif blank.gif menu_background_l.gif home_off.gifseparator.gifcoveragearea_off.gifseparator.gifservices_off.gifseparator.gifprinters_off.gifseparator.giftechnical_off.gifseparator.gifsearch_off.gifseparator.gifenquiries_off.gifseparator_r.gif menu_background_r.gif blank.gif 0001002D Cleaning unit EOL
Just like any other mechanical equipment, a printer requires attention to keep it running smoothly. So, just like when the check engine light illuminates on your cars dashboard so does your printer, but instead of a spanner the error 0001002D will appear on your control panel LCD which is informing you that a maintenance procedure is due to be performed. This will normally involve replacing the parts which keep the print head clean, hence the error "cleaning unit END OF LIFE" and the waste pads. This procedure can be undertaken here at Large Format Repairs for the Epson Stylus Pro 3800 right upto the beast that is the Stylus Pro 11880.
worn_flushing_box.jpg worn_cap_assembly.jpg Worn flushing box Worn cap assembly worn_head_wiper.jpg worn_carriage_waste_pad.jpg Worn head wiper Worn carriage waste pad
Pson styllus pro 7800 service call error 0001002d.. help
this error 0001002D means Cleaning Unit end of life
techbelkin
11helpful
2answers
Epson styllus pro 7800 service call error 0001002d.. help
http://www.largeformatrepairs.co.uk/technical/maintenance-error-code-0001002d.htm
This happens when you let the "maintenance req. 0040" go for to long. The machine turns itself of to prevent damage.
Solution: Call epson and they will give you the reset code. Cannot find these codes online so if you do call please post instructions
Please rate the answer........
2helpful
Bulb replaced but tv switches off and flases 3 times(red)then green
Check the lamp door it has to engaGE THE SWITCH OR IT GIVES YOU A 3 BLINK ERROR.
2answers
REQ 0001002D
This is the result from running the machine with the maintenance code of 40 for too long (needs service parts replaced including pump cap assy and then reset counters). I have all you need (full maint manual, reset software and parts) if you need them. [email protected]
2helpful
2answers
LG DLP RU-44SZ51D Lamp Indicator blinks red
44 inch lg dlp hdtv no picture or sound press power button standby light turns yellow and then back to red
5helpful
Service required error 0001002d
2answers
Flasing red light
The flashing red indicates that either the fileter cover or the lamp cover is not installed correctly. If both are installed properly and secured, the unit will require service.
Dan
Top Epson Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
NH TECH
Level 1 Expert
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
