Please help. I have a mitsubishi projection tv WS-65908 has sound but no picture on all inputs. If I select an input without connecting source then screen turn blue screen. If connected with input source like DVD player signal or antena then screen turn black with sound but no picture. Press "menu" on remote control can not see anything. Could anyone help any idea how to fix? Your help is a greatly appreciated.
[email protected]
SOURCE: Mitsubishi WS-55311, 4 yrs old, flashing screen on all inputs
First thing to try is to press the reset button on the front of the TV. This forces a system reset.
SOURCE: Mitsubishi remote and control panel issue
The control panel circuit board was replaced at a cost of about $40 for the part plus $150 for the house call.
SOURCE: mitsubishi WS-55311 flashing screen
First suggestion is to unplug your unit for 24 hours, if does not correct your concerns, you may have fluid leakage from the tubes onto the pc boards. Make sure you have proper air venting around the tv. If problem persist call factory authorized dealer in your area. good luck
SOURCE: TV screen goes blank but power stays on
Sounds like the CRTs are going into protective blanking due to the vertical output ic needing to be resolderd. Try resoldering the vertical IC that may possibly fix the issue.
SOURCE: tv mitsubishi ws-65315 doesnt turn on,only green light
Good Day, cutito35; 1. This model is equipped with a keyboard lock feature; this can be mistaken as a no power condition. To unlock the keyboard press and hold the "menu" button on the front panel for 10 seconds. 2. (Power LED may be on after plug in) check for no less than 4.4 volts DC at pin 3 of PC9A21 on the Power PCB, if low or missing replace PC9A21 part # 268P058020. 2.This model is also equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) 1. Shutdown at power with self diagnosis error 2-2. Check for open fuses F9A04 and F9A05 part # 283P144080 on the +24 and -24 volt lines. If the fuses are open the convergence output circuit would be suspect. 2. Shutdown at power with self diagnosis error 2-1. At power on check for 12-volts DC at connector KH pin 8, if missing check IC9C51 part # 270P990010 and L9C52 part # 441D009020 on the Signal PCB. Good Luck, big IRISH.
