Every time i plug in my charger my phone wont charge and it turns on and turn off.........
  • 506 Answers
There is a partial contact between the phone and the charger. Make sure the contact between the phone and the charger is firm and okay. Also check that there is no cut in the charger cable. Try and change the position of the cable along its lenght to see if there is a position the contact is okay.
Posted on Jun 09, 2010
    Scholar:
  • 128 Answers
Hi! kindly try to drain the power charges of the phone by disconnecting the battery from the phone unit. Connect back battery and make sure that the charger is connected properly on the charging port of the phone. Please make sure you are connecting to a stable power outlet.
6ya staff
SOURCE:
Once i plug in my charger its wont charge!
Turn it off, & keep it off for a while. It's happened to me as well. Turn it back on & plug the charger in.
Dec 16, 2011 | Sanyo SCP-2700 Cell Phone
Tip
How do you fix your phone if it wont charge? ...
All you need to do is shut down your device, remove the battery if possible and use something small, such as a toothpick, to 'lever up' the little tab inside the USB port on your smartphone or tablet. Do so very carefully and gently, then reinsert your battery and plug it in again.
or this.
  1. Turn the phone off.
  2. Remove the battery.
  3. Wait 10 seconds.
  4. Plug in the charger.
  5. Insert the battery.
  6. Turn on the phone.
How to fix phone that won charge properly AndroidPIT
SOLVED Why won my Samsung Galaxy II charge Samsung Galaxy II
How to fix phone that wont charge
How to fix Samsung Galaxy S6 that not charging Troubleshooting Guide
Why is my Samsung charger not working Google Search
on Dec 12, 2017 | Samsung Cell Phones
Rokr e8 won't charge
when the phone discharges completly, it can olny be charged via the charger that plugs into a wall outlet.
Aug 04, 2009 | Motorola Mobility ROKR E8 Cellular Phone
Motorola razr v3 wont charge, the bettery is not that old the phone beeped to signal charge requred, plugged it in as usual but cant turn it back on.
If the charger is plugged in, the phone is hooked to it, and it still will not come on, I would think it's a charger or electrical outlet problem.  I think most phones will bypass the battery power if they are plugged into an outlet, so try another wall plug, and if that wasn't it, try a different charger.  If a different outlet and charger don't solve it, it may be time to take it to the store to be checked.
May 29, 2009 | Motorola Mobility RAZR V3
My iphone wont charge
please use a functional charger...
Feb 03, 2009 | Apple iPhone Smartphone
Wont charge or is locked
if you plug the charger in and you can see the battery bars going up and down then it is phone problem if the scrren is blank then it is either the charger but if you have a car charger aswell and both chargers worked before then it is probably the phone that has a problem check where the charger plugs in that their is nothing blocking the terminals like fluff or bit of paper check that none of the terminals are bent or coroded if you have used phone in rain they might have got coroded this can be solved by cleaning the terminals on the charging part of the phone but be carefull when you do this not to wreck any thing check the charger make sure nothing bent or blocking the charge the problem with these phone is the pins on the bottom where the charger plugs in these get damaged really easily and they can be replaced but will have to take to phone shop and get repaired hope this is some help to you....................................
Nov 12, 2007 | Motorola Mobility L6 Cellular Phone
Razr wont charge
It's really sad that u r on a boat because i suggest u may need to get a desk top charger for your phone. Most times these unable to charge problems comes mostly from water damage or your phone been plugged in to the wrong voltage. Sam !
Jun 30, 2007 | Motorola Mobility RAZR V3
Computers & Internet Logo
85 people viewed this question
Ekse
Marvin
Marvin
