Question about Sander 6" Bench Grinder 2" Belt Combo Unit
I have an Abbott & Ashby 200mm Industrial Bench Grinder - CS-8GCM I need to change the sanding belt and am unsure how to do it, can you help?
Posted by topaz45 on
Anonymous
    Problem Solver:
  • 10 Answers
Remove/open cover on the right side of belt assembly housing. push downward on tracking knob left side top of unit.Belt is spring tensioned to remove slack.Push down remove old belt,push down again for new belt.With belt running adjust belt track(centering) by turning knob,top of unit,toward or away from you,Arrow on inside of new belt governs direction of rotation of belt.
Posted on Aug 10, 2010
What is wrong when bench grinder stalls out when sharping mower blades. Not too much pressure used. Grinder not equipped with a belt
since this is a vague comment, I have to say that some small grinders just do not do well with blade sharpening. I have one that does the same thing when sharpening a blade. It is just too small, horsepower wise, to handle the job.
Sep 29, 2017 | Bench Grinders
Can I purchase eye piece for nutool NTG6L grinder/sander
says not to Canada. May be good for you?
Nutool (2) - Nutool
nutool.pl/gb/1_nutool?&p=2List of products by manufacturer Nutool ... Dust collection bag , easy sanding belt replacement , continuous running ... Bench Grinder NUTOOL 150W/150mm.
other suppliers
nutool NTG6L spares Google Search
Apr 23, 2017 | Tools & Hardware - Others
I have a very old Nutool NTG6L which is a combined grinder and 2" belt sander. Is it still possible to buy new sanding belts for this machine or is it too old?
I suggest doing a search on eBay. Depending on where you live, you may need to find them in another country. A Google search might help first but I found these on eBay Ireland.
2 Pack Of 3 Sanding Belts Nutool Nu Tool NTG6L 6130 Bench Sander
Nov 29, 2014 | Tools & Hardware - Others
My ryobie bench grinder keeps tripping the rcd within a second of turning it on?
Assuming your local tech confirms that your bench grinder tests ok. The problem is probably that the grinder draws too much current for the RCD and is therefore detected as an earth leakage. High amperage devices often do that. Your best bet would be to plug it in to a socket which is on a non-rcd circuit. Maybe you have an RCD on the whole house though? I would start with returning the grinder and trying a different brand with a lower amperage/wattage rating. If that doesnt work, I would call an electrician to discuss installing a different RCD or running a separate circuit for your power tools.
Mar 03, 2011 | Jet Industrial Bench Grinder 6in new
Have 25 year old Wilton belt grinder. Belts seem to wobble when running then will just not track. Not sure what part needs replacement.
The motor and grinder pulleys need to be perfectly parallel or the belt will track to one side or the other. The belt must be uniform with no stretch or wear points which will cause erratic travel. Hope this helps!
Nov 09, 2010 | Wilton Variable Speed Wheel Grinder, Bench...
I have an old 2 piece bench grinder that was wor...
Could be a belt tension issue. Try tensioning the belt by moving the motor and wheels farther apart by reanchoring the units,or,spanning the gap between units with a series of wood blocks and shims(wedges).Be careful with tensioning. Always manualy move the belt,unit unplugged. There should be some deflection(play) in the belt when pressed upon with a finger.
May 20, 2010 | Grinders
Ryobi Bench Grinder with Linisher tracking difficulty.
It sounds like the pulley is not adjusted correctly. This is causing the belt to move on you. Carefully inspect and adjust the pulley so it is square and flat. Use a straight edge.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Jun 25, 2009 | Grinders
Grinder won't stay running
The capacitor is easy to change and can be matched once you remove it by any electronics parts house.
Nov 24, 2008 | Delta 23 884 8 Inch Bench Grinder Wheel,...
Sander 6" Bench Grinder  2" Belt  Combo Unit Logo
324 people viewed this question
Top Sander Grinders Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Vernon Taylor
Tom Chichester
Are you a Sander Grinder Expert? Answer questions, earn points and help others
