If the disc does not rotate it means there is something wrong with the power supplying the disc motor or the motor itself is defective. Try to rotate the disc motor manually, If its rotating freely then the problem is in the circuit that supplies the disc motor.
Try play the dvd disc on another DVD player. If it can play, maybe it is the problem of the DVD player. Then you can check on this:
"How to fix a DVD "No disc" error".
Also, maybe you didn't copy the DVD disc in a right way, such as the copied DVD contain incompatible region code with your DVD player or copyright protection. In this case, you need to get another DVD copy software that can copy this kind of protected DVD, such as Leawo Blu-ray Copy which can deal with it.
