Someone borrowed my phone and it doesnt ring out now when i try to turn the volume up it keeps telling me to exit silent profile but dont know how to do that ive tried resetting the settings and its asking me for a pin code but i dont know the pin code
If you are using Android phone you need to make sure that the ring-tone volume is not muted. Just goto setting and sound and then increase all the volume, sometime even if the phone is not in silent mode it won't ring due to Android sound settings . You can also use the volume rocker key to increase the ring tone volume. Just in case also change the ring-tone as well in case if the ring tone file is corrupt. Now try ringing your phone from another phone and see if that works. If it still doesn't work, just turn off your phone and take the battery out for 10 seconds and put it back. Try ringing it again. If nothing works, there might be problem with your built in speakers. And you need to contact the manufacturer.
It would be better if you could tell your phone make, model and mobile operating system name and version, to help you further.
either your profile is silent or your volume is down. whenever your profile is in silent mode/vibrate mode even if someone is calling you it wont ring. change that to ringer via settings and sounds.
1. Try to make sure it is not on vibrate or silent.(usually indicated by an icon of a shaking phone at the top right of the screen) It can usually be turned on and off by holding down the star button.
2. Make sure you have your volume up.
3. Change your profile. Usually there are different profiles on phones for different places, i.e outdoor, silent, vibrate, etc... It can probably be found in the settings under something like audio, ringtones, profiles, etc.
4. The phone may just be deffective. I would suggest if after trying the above it doesnt work, to contact either your phones manufacturer or your cellular service provider. They may be able to help.
Change profile to silent, then go back into general profile & select 'personalize'. Go to Keypad Tones & turn off, then click back & select 'activate'. You should now have no keypad noise and the phone should ring.
you can go to profiles and select silent or meetings profile otherwise select ringtones and turn off volume for ringtones. If you dont find any of these option then kindly let me know what is the model no. of your phone
samsun 3500 do not have a keypad tone and when i try putting volume it tells me exit silent mode i am not in silent mode and my phone does not ring either
You can change the settings of the selected active profile.
Select Menu > Settings > Tones > Incoming call alert, Ringing tone,
Ringing volume, Vibrating alert, Push to talk settings, Message alert
tone, Instant msg. alert tone, Keypad tones, or Warning tones. You can
find the same settings in the Profiles menu.
May be you selected the " Silent Profile " by accident in settings. Go to Menu > Settings > Profiles > and see what you have
Choose something other than Silent and Activate see if your phone rings !
