Question about Canon Rebel XT / EOS 350D Digital Camera
Camera take pictures but all buttons (menuset and more not working)can not do setings and playback on lcd monitor thanks
    New Friend:
  • 94 Answers
I have seen this fault after a blown fuse caused by bent pins in the CF unit. I think the camera needs to be taken to an expert for repair.
Posted on Jun 09, 2010
Nikon d40 monitor is black when camera is on
Does the menu show when you press the MENU button? Can you see your pictures when you press the Playback button (right-pointing triangle)? If so, then there's nothing to fix.
The D40 works as SLRs have worked for half a century. There's a viewfinder which allows you to frame and compose your picture. The LCD monitor is for menus, camera settings, and picture review. LiveView, which allows you to use the monitor for shooting, is a recent development, which Nikon introduced into their cameras with the D3 and D300, both introduced years after the D40.
Dec 05, 2011 | Nikon D40 Digital Camera with G-II 18-55mm...
LED BLACKED OUT
Could be a problem with the CCD circuitry. You will need to get it serviced, I'm afraid.
Jun 19, 2008 | Pentax Optio S5i Digital Camera
Fuji Finepix S5700 digital camera. LCD green-pink
try to playback previous images ..If screen looks good on playback and or main menu..Camera likely has problem with CCD imager and camer digital processor board.If camera also looks bad on playback and menu..its possible the LCD IS BAD..easy test is to hook up camera on a monitor or computer and see what picture on camera mode looks like..If it also looks bad on a different monitor..Then CCD imager could be bad..If playback and camera mode lokk bad on monitor ..then you have a video process board problem ...please let me know
Dec 18, 2007 | Fuji FinePix S5700 Digital Camera
The Monitor screen doesn't work when I want to take a photo, I can only see picture through eye piece.
If your screen works in playback mode, the screen and flexible circuit boards are intact. To shoot an image using the LCD screen you must first activate the "live view" function in the setup menu, and then press the live view (Lv) button to view your image on the LCD.
Nov 05, 2009 | Nikon D90 Digital Camera with 18-105mm...
Canon A75 no images on LCD when shooting
Possibly the same problem I just had with my A75 (and shared with another post here).
Below the LCD are two buttons (versus four on the A70). The button on the left is the Print/Share button, which is new to the A75, while the display button (DISP.) toggles the LCD and what's shown on it on and off.
Hope this works.
Jun 07, 2009 | Canon PowerShot A75 Digital Camera
I have a Nikon d70, and I can not get it to display only one image on the LCD screen. I have held down the button on the top right side as directed, but to no avail. Help Jb
Push your playback button once the camera is on.
Then push you your thumbnail button. (this is the second button from your playback)
watch your monitor and keep hitting the thumbnail button until you get to the single picture view.
Dec 07, 2008 | Nikon D70 Digital Camera with 18-50mm Lens
My LCD Screen..
Your flat-wire connection between LCD monitor and the monitor PWB inside the camera is broken. can't fix it by yourself. Look for a Panasonic authorized service only!
Sep 20, 2007 | Panasonic PV-GS31 Mini DV Digital...
LCD Display
If you mean you see no picture on the lcd monitor before you take the picture and see it only after you have taken it than this is normal with digital SLRs. But if you mean you see nothing on the lcd monitor after you have taken a picture ( no playback ) then either the shutter is not working , or the CMOS sensor is not working or the camera is not communicating with CF card.
Sep 09, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Powershot S1 IS trouble shooting in images of lcd monitor
Try playing back pictures you know were captured properly ( either with another properly working camera or with your camera before the problem with quality has appeared ). If the image is ok in playback but 'noisy' in capture mode then the CCD sensor is faulty /on its way out. Ask Canon if they repair CCD faults on this model free of charge.
Aug 18, 2007 | Canon PowerShot S2 IS Digital Camera
LCD Monitor on ,and the Electronic Viewfinder turned off
If you turn on the back LCD, the electronic viewfinder will remain on while in a shooting mode. There is no setting on the camera to use only the back LCD monitor while shooting. If you playback images in the Play mode, only the LCD monitor will turn on. However, if you press the Monitor button while in the Play mode, than the back LCD monitor will turn off. The image will display only in the viewfinder LCD.
Sep 04, 2005 | Olympus Camedia C-730 Digital Camera
Canon Rebel XT / EOS 350D Digital Camera Logo
89 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Ekse
Poul Brinchs Larsen
Are you a Canon Camera Expert? Answer questions, earn points and help others
