Question about Camping, Backpacking & Hiking
Trying to find replacement bulbs for our Swissgear rechargeable camping lantern - the part numbers are on the bulbs (F4T5/D) but cannot find them anywhere. The closest I have come is finding the identical lantern, but no parts.
Posted by bumpisjr on
Boneebone
  • 973 Answers
Can I get a battery compartment for Innovage outdoor Lantern
Find the exact model number and try: https://www.ebay.com/sch/i.html?_from=R40&_trksid=p2380057.m570.l1313.TR0.TRC0.H0.Xinnovage+outdoor+lantern+parts.TRS5&_nkw=innovage+outdoor+lantern+parts&_sacat=0
Nov 09, 2017 | Innovage Camping, Backpacking & Hiking
Need to change battery in my 4345 lantern
If you are talking about the Coleman 4345 lantern it is rechargeable using one of the chargers (mains or car) stored in the base. Are you saying it won't recharge?
Mar 30, 2017 | Camping, Backpacking & Hiking
How do I remove the battery?
try grabbing it with pliers. sounds like it is corroided
Aug 02, 2017 | Coleman Dc 12 Volt Inflate-all Pump
This is not intended to be a user replaceable battery, although I have found a replacement battery on-line.so that means that SOME people have replaced them. the cost is $9 +s&h. I don't think most camping outfitters would be able to help you with it, But it would be worth a try.
My suggestion would be (if you have one in your area) take it to a Batteries Plus store. They are quite good at replacing batteries that are NOT meant for user replacement.
Best of luck to you.
May 12, 2014 | Coleman Camping, Backpacking & Hiking
Swissgear rechargable lantern won't light up, even though the green led light indicates it is fully charged
There are several different models of the Swiss Gear rechargeable lantern. On most though, you can remove the top portion of the lantern and check the lighting element inside. In most cases the elements can be removed and replaced. I have a dual filament lantern and from experience I know that every so often you may have to go buy a replacement light piece. If the lantern has been bumped or even just strapped to the outside of the pack while walking, it's possible for those elements to become loose and need repositioning or replacement so do check that. I'm sure that it should be unlikely your charger is malfunctioning unless you left it plugged in for some very extended period of time, in which case I would say the light would be more likely to burn out. But definitely try that and if that doesn't work the battery pack on the lantern itself may have an issue in which case you can always get a replacement.
Aug 29, 2012 | Camping, Backpacking & Hiking
What is solar camping gear?
Solarcamping gear is a great environmental solution that allows campers to use thenatural sun to power camping equipment instead of needing batteries foreverything. You can get solar spot lights, battery chargers, generators, andeven solar showers.
Aug 02, 2012 | Camping, Backpacking & Hiking
I am trying to find a 120 Volt AC adaptor for my Swissgear lantern.
The adapter need to match the charge voltage requirements of the battery in the Swissgear lantern.
This voltage maybe written on a label on the lantern.
i suggest go to the shop where you purchased the lantern for the charge adapter.
Jun 02, 2012 | Computers & Internet
Lights on Rechargable Lantern.. Swissgear SG66301
I don't know how to solve your problem but, the three lights mean this:
Red LED light indicates the battery is being charged
Green LED light indicates that the battery is fully charged
Amber LED light incidates that the battery power level is low - the battery needs recharge.
Do not recharge you battery over 24 hours.
Nov 03, 2009 | Kitchen Appliances - Others
Rechargeable Camping Lantern
you need to coldsolder the pc board.
Apr 09, 2008 | Dryers
Camping, Backpacking & Hiking Logo
1,361 people viewed this question
Top Camping, Backpacking & Hiking Experts
Tom Chichester
Kardoc
ray gallant
Are you a Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
