Question about Dometic Rooftop RV Air Conditioner
I have a Dometic RV airconditioner roof mounted, the model number shown on a tag inside the unit says it is Model CAL 136.312 Product Number 991650423, I cannot find this model in the Dometic catalogue is their a corresponding number for this model?
Posted by alex_polotni on
Mike Butler
  • Dometic Master
  • 6,674 Answers
Your probably looking at the control module number or something in that area. When you have the ceiling assy off as in cleaning filters, look for a sticker directly on the base of the roof unit. Look all around on that base, even behind wiring harness, you should find a model number and serial number.
Posted on Jun 10, 2010
Mike Hanson
Did you get the model number?
Posted on Nov 21, 2020
Anonymous
    New Friend:
I have the exact same unit with this information found as described on a sticker on the bottom of the base unit. I also can't find this model on the Dometic site.
Posted on Jul 14, 2010
Need a replacement r v air conditioner shroud polaris by dometic 28inches wide 41 7/8 inches long & 9 1/2 inches high
Can you get model number of bottom of upper unit, from inside the trailer? The roof unit model number will make it easier to find replacement shroud.
Sep 27, 2012 | Dometic Rooftop RV Air Conditioner
What model number Dometic AC unit to add to RV?
You can use Dometic Brisk Air II model for your RV. It has 13,500 BTU capacity. I used this air conditioning unit for last 2 years on my RV truck. If you want to know more about this unit, you can check this link. https://coolingmyrv.com/
Jun 26, 2012 | Dometic Rooftop RV Air Conditioner
Need the schematics for 6721A or 6723A Coleman RV air conditioner
Check this link but look for model number on base of roof unit. Roof unit will be one number and whatever ceiling assembly will determine what to do with wiring.
http://www.rvcomfort.com/rvp/tech_info/manuals.php
Jun 19, 2011 | Dometic Rooftop RV Air Conditioner
I have a new Salem travel trailer with Dometic products. Everything appears to work fine, but when I run my furnace and it turns on, my fan blows from my AC unit. I have owned 2 other RV's but...
Yes it sure does sound like something may be wired wrong, Could you please reply with model number of your AC unit as well as thermostat model? To find your AC unit model number if you don't already have it, remove your ceiling air filter assembly, and it should be on the base of the roof unit, facing you.
The base of the roof (upper) unit will have a model and serial number, and if you see a control box where all the wiring attaches as well, get model number from that too if you will. Those numbers should make it easier to determine exactly where the problem is. Thanks.
May 28, 2011 | Dometic Rooftop RV Air Conditioner
Installing rv roof airconditioner heat strip
I see what you see also in the manual. The difference is the Heat Strip package that part is optional and the 600212-001 with the optional heat strips becomes the new 600315-001 I talked to Dometic Duo-Therm and the models are the same but they both are not heat pumps but the new heat strip package comes on when told to go into heat mode when you change the thermostat to heat. The part you purchased will fit both model numbers you listed for your roof top air conditioner. Thanks, Sea Breeze
May 09, 2010 | Heating & Cooling
My Dometic Rv ac is not cooling but, the fan does run..
Can you give me the model number of your AC unit. There should be a sticker on the bottom of the upper (roof) unit, that you can see when you take the filter down from the ceiling inside. Also need to know if it's a wall thermostat and what brand/model, or are the controls at the ceiling.
Apr 24, 2010 | Dometic Rooftop RV Air Conditioner
TRYING TO FIND THE RIGHT DUCTED AIRCONDITIONER COLMAN. FOR 1995 TRAILER
The upper unit doesn't matter ( the actual ac unit on roof ) it's the lower control unit (inside at ceiling) that you need to change to use either ducted or non-ducted system. Any RV dealer can supply that, probably have it on the shelf. Just make sure you write down the model number and serial number, off the bottom of the upper unit, so they can match lower unit to it, for ducted system.
Apr 14, 2010 | Dometic Rooftop RV Air Conditioner
Lance RV A/C problems
Are you sure those are the number of the base of the upper (roof) assy, and not off the lower assy ( ceiling assy) ? Try calling 1-574-294-2511 ( dometic) they can confirm if model # is currently new model. 63... is fairly current so maybe the 64... latest.
Apr 11, 2010 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
1,093 people viewed this question
Top Dometic Heating & Cooling Experts
Marvin
Marvin
Sheldon Dedek
Mike
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
