Hi Guys, wonder if anyone can help my 04 plate focus tdci ghia looses power in all gears. When i took it on the motorway it was a drag through the gears. Seems like it holds back power ?
many thanks
Ive a 03 mondeo ghia x, 2l tdci,130bhp have then same cutting out problem, had new battery, new injectors and recoded still the problem is there any1 no y, diognostics test done which was injectors but still no luck same as b4
Bound to be frozen at the pumps, even the pumps will freeze up hence no noise, it should self-sort after the engine has been running a while, the heat off the motor normally does the trick.
I would doubt it is a fuse but yes they do run through a fuse.
Pick up a screen wash sachet that contains anti-freeze from the gas/petrol station, empty the contents, it will slowly work it's way in and thaw out the system.
check that the antenna is plugged into the back of the unit or look under your fender and make sure it is plugged in there as well or use manual search instead of autosearch
ive had the same problem with my ford focus 1.8 tdci wont start at all towed it to fords who says its the fuel pump and its ganna cost 600- 1,000 pounds hope this helps.
