Hello Mr
Xbox 360 Repair – Want To Beat The Red Lights And Get Back To Gaming? Read This!
If you are looking for a way to repair your Xbox 360 from home
without having to wait for 4 weeks and have to pay out a lot of money
for repair then this blog post will tell you how to do this.
You see the problems are caused by overheating and the main problem is the Xbox 360 3 red lights however you may also get disc reading problems, freeze ups, 2 red lights and 1 red light error codes as well.
So if you get these problems what can you do to perform Xbox 360 Repair?
Well you can send it in and they will repair it for you however this
will take about 4 weeks and cost you money for the repair as stated
above.
What a lot of gamers are doing is taking the matter into their own hands and performing Xbox 360 Repair from home.
Now this sounds a lot more difficult then it actually is and and as
long as you stop the heat build up you will be able to play your games.
To do this you can use a good Xbox 360 Repair guide that will show
you how to stop these errors from home and the best thing is that all
you need is a few household items.
There is an Xbox 360 Repair guide that will give you step by step
videos and a full walk-through for all of the errors so all you need to
do is follow through and you will be able to perform Xbox 360 Repair at
home with ease!
Check out the full guide and see how easy it is to fix:
Xbox 360 Repair
SOURCE: Bottom right corner red flashing light error e 74
From the Xbox website sounds like you have a HDD failure / issue.
Try the following steps to resolve the problem:
1.
Turn off your Xbox 360 console.
2.
Removethe Hard Drive. For more information about how to attach or remove theXbox 360 Hard Drive, click the following article number to view thearticle in the Microsoft Knowledge Base:
906204 (http://support.microsoft.com/kb/906204/ ) How to attach or remove your Xbox 360 Hard Drive
3.
Reattach the Hard Drive.
4.
Turn on your Xbox 360 console.Ifyou continue to experience this problem, obtain the latest automaticupdate for your Xbox 360 console. To do this, follow these steps:
1.
2.
Detach the Hard Drive.
3.
Connect the console to the Internet through an Ethernet cable.Notes
Toobtain an automatic update without your Xbox 360 Hard Drive attached,you must have an Xbox 360 Memory Unit or an Xbox 360 that has built-inmemory.
If you cannot connect to Xbox LIVE, running a recent game (2007 or newer) causes an automatic update to be installed.
You can also obtain the latest Xbox 360 system software from the following Xbox Support Web site:
http://www.xbox.com/support/ (http://www.xbox.com/support/) If applying the latest automatic update does not resolve the problem,please contact Xbox Customer Service. If the Customer Service agentcannot help you resolve the issue, you may have to replace the HardDrive. Discuss your replacement options with the agent.
For moreinformation about how to contact Xbox Customer Support, or to submit arepair request, please visit the following Xbox Support Web site: http://www.xbox.com/support/
