Cannot cancel documents in the print cue.
I have an HP Deskjet 3845 connected to a Toshiba Satellite R10 running VISTA. I cannot cancel the first document in the print cue. The first doc would not print and I cannot get it to cancel. Any doc you add to the print cue now won't print either but I am able to cancel these latter ones.
  • grinnellski Mar 12, 2009
    hp oficejet 6310 all-in-one - one document is stuck in que; it says it is cancelling, but it doesn't go away. It doesn't print either. But it does block all future print jobs. I can cancel those, but not this one particular document.
5 Related Answers
Anonymous
  • 55 Answers
SOURCE: HP3845 Printer will not work in Vista
Just go n visit this link,but before this uninstall the old driver completelyhttp://h10025.www1.hp.com/ewfrf/wc/document?docname=c00808543&lc=en&cc=us&dlc=en&product=372330&os=2093&lang=en
thnx N
Posted on Jan 29, 2008
Anonymous
SOURCE: HP Deskjet 9300 cannot print A3 size documents
Thanks for the help Simon. I really Appreciate it. Have tried that already to no avail! Sadly! I think the poor thing may be coming to the end of its short but useful life!
Thanks again. If you can think of anything else I could try, please let me know.
Steve
Posted on Mar 14, 2008
Anonymous
  • 64 Answers
SOURCE: need hp deskjet 3845 driver
Check here:
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=372330&lc=en&cc=us&dlc=en&lang=en&cc=us
Posted on Jul 20, 2008
Anonymous
  • 1605 Answers
SOURCE: Docs in queue won't cancel so I can print another document
turn of the printer and unlug the data cable.
go to start>>printer and faxes, open the printer queue and deleted the job.
plug in the data cable and turn on the printer
Posted on Jan 29, 2009
Anonymous
SOURCE: problems printing with HP Deskjet 1280
When I printed powerpoint documents on a hp deskjet 1280 it failed to print lines. I found that this problem could be solved by changing the transparency attribute of the line to 50%. The transparency attribute of a line or shape can be found by clicking on the sequence format/shape-outline/more-outline-colours/transparency at the top of the screen
regards
Graham Pratten
Posted on Apr 27, 2009
I cancelled a printing sheet of paper and now it won't print anything.
Did you try turning off then back on or unplugging it and plug it back in. Open up your printer folder and clearing all documents?
Downloaded driver from HP. connected printer via
HP Support says “If the Ready light is blinking, and the Go light is on, it indicates Data in the printer memory is waiting to be printed. Pressing the GO button prints from Tray 1 or from another tray if Tray 1 is empty and the paper size is supported in the other Tray. Pressing the JOB CANCEL button cancels the current job and the printer returns to ready.
Make sure the paper size is correctly defined.
2helpful
My hp deskjet 3845 is not printing, it says there is a document printing but i have cancelled all documents - any ideas?
Hi Jamie,
You best option is to reset the printer spooler. 1. First turn your pritner off. 2. Then in you PC, click on "start". 3. go to "run" 4. type in: CMD 5. This will bring you into a DOS window.. In the DOS window type: net stop spooler (press enter) 6. now type: net start spooler (press enter) 7. now type: exit (press enter) 8. Now turn on your printer.
This should have rested the printing system.
Regards, Ed
HP Deskjet 3845 not printing...
the same thing happened to me and i uninstaleld it and reinstalled it, try that or check because something really small could be stuck.
What's happening?!?
Please reinstall your printer driver for initial fix.
HP Deskjet 3845 will print the web page, but wehn I try to print a short word document it feeds a sheet through, but prints nothing
plz try by reloading the printer driver and check if you have correct paper size selected in the printer.
2answers
Printer is not printing at all
You may not install the correct driver for the correct OS. Not sure what OS you are using but below link might be useful for you to get the correct driver and install into your PC.
http://etech.maiila.com/hp-deskjet-3845-driver-manual-software-download-and-troubleshooting-tips
Hope this helps
1helpful
How to cancel a printing
Go to Start-> run . Type in services.msc. Find the print spooler service, right mouse click and choose stop. Open Explorer and go to c:\windows\systerm32\spool\printers and delete all files.
Go back to services.msc-- Print spooler. Right click and start service
1helpful
thnx N
HP Deskjet 3845 print queue not clearing
Have you tried going to safe mode, turning off the printer and manually opening it at the control panel>printers... try and delete or cancel prinitng at these settings...
Ekse
