GE Adora DVM1850 Microwave Oven Logo
Anonymous Posted on Jun 08, 2010
Microwave does not heat
My Microwave turns on and rotates, but the microwave does not heat. It also seems as if sounds a little different as well.
John Riley
Level 3:
  • Master 441 Answers
  • Posted on Jun 08, 2010
John Riley
Master
Level 3:
Answers
441
Questions
Helped
138510
Points
1344
Your magnatron tube (what heats the food) is out, if it is not still in warranty it will run 200-300 to fix, might be better to replace sorry
Testimonial: "The you for quick response and solution to the fix."
Siemens HF26066GB plate is moving when door closed and not moving when open
Have a shop look at this---there usually is a recessed safety switch inside the jam that will prevent the unit from working with door open--sounds like the problem may be with it.
Hi there, unit worked fine this morning heating coffee, now has a different tone, and not heating. Timer works, interior light comes on, turn table rotating. Unit is a KEMC308KSS01
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
Oven not heating. runs but no heat. GE Spacemaker (11 years old) Light works, table turns. Seems a little louder when turned on
Basic
heatman101
Unit operates does not heat anything
A defective diode or magnetron can cause the oven to sound differently and not to cook.
1helpful
Microwave seems to work but doesn't heat up
HI, when the Magnetron becomes unstable, the microwave will not heat anything. simply replace the Magnetron. This device creates the heating action and it is damaged and not functional at this time.
6helpful
Turns on but not heating food sounds a bit louder
Hi, this is common in most microwaves. this abnormal noise is coming from a faulty Magnetron. this device is responsible for the heating process and, it is damaged and not heating at all at this point.Simply replace the Magnetron and, this unit will start to heat once more.
1helpful
Not working
When the microwave sounds okay, but there's no heat, one of the internal door switches, the high voltage circuitry, or the circuit board may have a problem. To resolve this problem, you need the assistance of a qualified appliance repair technician, as repairing microwaves is a pretty risky job.
Hotpoint RVM1425
The first thing I would suggest is to turn off the breaker or unplug it from the wall for a few minutes to "reset" it, then try again. If a reset doesn't fix it, I would think you may have a defective magnetron. When you heat something of very low moisture content, it can lead to microwave energy not being fully absorbed, but instead being reflected back to the magnetron. This can damage it. This is usually best left to a pro to repair. In case it might help, your owner's manual can be found online at: http://products.geappliances.com/ProdContent/Dispatcher?REQUEST=SKUOBJECTS&DOCUMENT=Use%20and%20Care%20Manual&SKU=RVM1425BA
Top GE Microwave Ovens Experts
vince
NOEL
NOEL
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
