Where can I find a manual in order to set it up.
SOURCE: Olympia, and/or Sharper Image infoglobe. Need fix.
It appears that you have already removed the 4 screws. The globe will not just fall off, it has to be pried. Take a small- bladed screwdriver or a small-bladed pocket knife and gently pry from any small opening you see between the globe and its base. Work the blade around the globe and it will come off. I just did it and now I'm trying to figure out how to get inside the "guts" of the globe. Will keep you advised.
SOURCE: olympia infoglobe
Funny that I came across this. I just now fixed this exact problem. This unit had failed after an electrical storm. Solution found elsewhere suggested removing the batteries and unplugging the A/C adapter for 10 minutes. (I waited 30). Reinstall batteries and reattach A/C adapter. Buttons worked to get to the erase memory option, which I did. Infoglobe is now functioning properly. This is also the instructions for clearing the "eeprom error" readout that many infoglobes exhibit after a power surge. Good Luck!
SOURCE: how to change time on Olympia Infoglobe caller id
I have the manual and can tell you what it says:
(this worked for me last year when we went off daylight savings, but for some reason, It doesnt seem to work anymore. I can't imagine that I did anything different then. You can try, though.)
Enter (or leave) the Demonstration Mode by pressing the right key for at least 1 second.
Then, by pressing SELECT key, you are SUPPOSED to be able to scan a menu which lets you pick date format, time format, etc.
This no longer works for me, and the instructions also have a contradictory comment that says the SELECT key is disabled in this mode. But perhaps this will work for you.
I would also appreciate instructions if anyone knows what I am doing wrong.
