Question about LG LS-L1210CL Mini Split Air Conditioner
Excessive rise of standard compressor discharge temperature. If over 105°C check refrigerant charge.
If over charged release some gas./ Condenser block clean it./ Less rpm f.motor-replace capacitor.
Posted on Jan 01, 2011
SOURCE: Error code ch33. How do
Has a problem in the internal sensor unit now who is not know, has three interventions However an N sensor and started tried to see who it is.
Posted on Oct 08, 2011
Sep 26, 2013 | Audio Players & Recorders
Aug 08, 2008 | Ricoh Aficio SP C411DN Laser Printer
FAQ ID: 44574
Last Modified: 22-Jan-09
Cause
Answer:
When an error occurs the camera will display an error code like "Exx", where "x" represent numbers.
See the list items at the bottom of this page when it shows following error codes.
"E18" error of the target unit / lens barrel
"E30" and "E50" error of the CF or SD card
When an error code "Exx" different from those already mentioned, the camera off and then turn to try to capture or play back images.
If this error persists or an error code appears often, there was a malfunction of the camera.
Note the error code and contact the retailer where you purchased the camera or the nearest service center for Canon.
I hope this helps
Jan 24, 2012 | Canon EOS-D30 35mm SLR Camera
Aug 12, 2011 | LG LS-L1210CL Mini Split Air Conditioner
Jan 01, 2011 | Bosch Washing Machines
Dec 25, 2010 | Rheem RTG-74PVN-2 Natural Gas Pronto Whole...
Dec 18, 2010 | LG LS-L1210CL Mini Split Air Conditioner
Nov 14, 2009 | Nintendo DS Console
May 04, 2009 | Panasonic Audio Players & Recorders
Oct 07, 2008 | Nokia 1600 Cellular Phone
854 people viewed this question
