I hope you already figured out how to scan on your Lexmark X2670. If not, here's the link to download the Lexmark X2600 Series User's Guide: http://www.lexmark.com/publications/pdfs/2007/x2600/v12357467_en.pdf. Scroll to Page 16 for Printer Control Panel buttons description. Scroll to Page 39 for instructions on how to scan. Hope this helps. If you need more assistance, leave a comment and I'll get back to it. Thanks.
Your PC may be running the Microsoft version of the driver instead of the set that came with the printer's cd installer.
So, FIRST, turn off printer and remove USB cable from PC.
Then, go to the windows control panel, then to printers/faxes and REMOVE the new printer.
After that is done, run the install CD that should have come with your printer. If the CD ask you to install all of just some software (such as the entire "suite") then do that. AFTER, install is conplete, restart computer.
Once computer is back up completely, plug printer back into USB and power printer on. Windows should detect the new printer and use the newly installed software from the manufacturer rater than the generic driver from windows. Scanner software should now be available from the LEXMARK folder in the START menu.
Using the printer control panel
1. Open the top cover, and then load an original document face
down on the scanner glass.
2. Close the top cover to avoid dark edges on the scanned
image.
3. Make sure that the printer is connected to a computer,
and that both the printer and the computer are on.
4. From the printer control panel, press the scan button.
5. Follow the instructions on the computer screen.
Using Windows
1.
Open the top cover, and then load an original document face down on the scanner
glass.
2.
Close the top cover to avoid dark edges on the scanned image.
3.
Do one of the following:
In Windows Vista, click > All Programs, and then select the printer program
folder from the list.
In Windows XP, click Start > Programs or All Programs, and then select the
printer program folder from the list.
4.
Click Lexmark Productivity Studio.
5.
On the main screen, click Scan.
6.
Follow the instructions on the screen.
Using Macintosh
1.
glass.
2.
3.
From the Finder desktop, double-click the printer folder.
4.
Double-click the 2600 Series Center.
5.
From the "What is being scanned?" list, choose the type of document to be
scanned.
6.
Click Scan.
Please download and install the scan driver from support.lexmark.com. After installing the scan driver, please check the scanner under Imaging Device from device manager. If scanner shows under imaging devices, open the scanning program and scan a document.
For further assistance, please contact Lexmark Technical Support.
