Rut Ro!
!O_O!
1) Three 'ribbon' cables are all you need.
Two IDE 40-pin cables, and One 34-pin Floppy Drive cable.
The wider 40-pin IDE ribbon cables are for the Harddrive, and Optical Drive/s. (CD/DVD drives)
(Actually 40 -> socket holes, and actually only 39 are used)
The narrower 34-pin IDE ribbon cable is for the Floppy drive.
http://en.wikipedia.org/wiki/File:ATA_cables.jpghttp://en.wikipedia.org/wiki/Parallel_ATANote*
I would like you to look at a Locating Lug, on an IDE flat ribbon cable, (IDE is also referred to as PATA),
http://en.wikipedia.org/wiki/File:PATA-cable.jpgNote on the blue rectangular connector, the two ridges at the Top/Middle. This is a Locating Lug. Shapes vary, but the same basic principle is kept.
http://en.wikipedia.org/wiki/File:ATA_on_mainboard.jpgNote the two IDE motherboard connectors. One Blue, one Black.
Note on the blue IDE connector that there is a cutout on one side.
(Outside edge of motherboard, Middle of side )
This is what the Locating Lug lines up with.
[Note also that IDE1 is silkscreened, on the outside edge of the motherboard, and between the blue IDE connector.
This is where the harddrive cable plugs into.
IDE2 which is right above (Black), is where the optical drive/s cable plugs into ]
IF, there is No Locating Lug on the flat IDE ribbon cable's connector;
The thin Red stripe on the side of the flat ribbon cable, denotes which side Number 1 wire is on.
Looking at your motherboard, with the Processor to the Top, and Ram Memory slots to the Right; Number 1 pin in the two IDE connectors on the motherboard, is on the BOTTOM.
The Red strip on the flat ribbon cable, goes towards the Bottom of the motherboard.
Looking at the back of your IDE harddrive, start at the Right side, go towards the Left;
On the right side are 4 pins. These are for the power cable. To the left of them are jumper pins. To the left of the jumper pins is where the flat ribbon cable plugs in.
The Red strip ALWAYS goes toward the power cable.
Same thing with an optical drive.
http://www.ebay.com/itm/ws/eBayISAPI.dll?ViewItem&_trksid=p4340.l2557&item=320584071749&nma=true&rt=nc&si=3aRaG4yZHczJd6Q3wXW2IIvaBys%253D&orig_cvip=true&rt=ncWith the above Gateway E-4000 motherboard example, the IDE connectors for the Harddrive, and optical drive/s, is at the Top/Middle.
The White connector is for the Optical Drive/s cable. (IDE2)
The Black connector above it is for the Harddrive cable. (IDE1)
The smaller black connector to the Left of the black Harddrive connector, is for the Floppy Drive cable.
The whitish opaque long connector under the black Floppy Drive connector, is where the 20-pin ATX main power cable plugs into,
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain20(Note color of connectors does Not matter)
3) Where the black Processor Fan is. Come to the Bottom/Right corner of it. Go straight across, and stop under the aluminum finned Heatsink, above it. (Heatsink looks like a meat tenderizer)
This whitish square 4-socket hole connector on the motherboard,
is where a 4-pin ATX +12 Volt power cable plugs in,
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4Note that both it, and the 20-pin ATX main power cable's connector, has a Lock on one side. This lines up with a Lock Tab on the motherboard connector. When the power cables are deemed to be tightly, and properly plugged in, the hooked end of the Lock will be over the Lock Tab.
This type of power cable plugs into the Harddrive, and Optical Drive/s,
http://www.playtool.com/pages/psuconnectors/connectors.html#peripheral(Commonly misnomered as a 'Molex' power cable. Molex was the first company to make the connector, and their manufacturer name stuck. Kind of like referring to an open-end wrench as a Crescent wrench)
4-pin Peripheral power cables may also be used for computer case fans.
(Yellow wires are 12 Volt wires. { DC }
Red wires are 5 Volt wires. { DC }
Black wires are Ground wires.
Do not hook up a 5 Volt fan to a 12 Volt wire )
Intel D845GRG motherboard is Gateway part number 4000828,
http://support.gateway.com/s/MOTHERBD/INTEL/2519530/2519530mv.shtmlThe front of your computer is the Front Panel.
The the area of contact pins on the motherboard, that the main wire go to from the Front Panel, is the Front Panel header.
In the list click on Q - Front Panel connector
Motherboard installed in computer case the Front Panel is down in the Bottom/Right corner. It is the second header over from the Right.
The pins across the Top row are numbered EVEN.
Starting on the LEFT side going towards the Right;
Pins 2, 4, 6, 8, 10, 12, 14, and 16.
The pins across the Bottom row are numbered ODD.
Starting on the LEFT side going across to the Right;
Pins 1, 3, 5, 7, 9, 11, 13, and 15.
A) Pins 1 and 3 are for the HarDDRive activity LED (Light)
Pin 1 is for the Positive ( + ) wire.
If the HDD LED is dim when the Harddrive is active, switch the wires around.
B) Pins 5 and 7 are for a Reset switch, IF a Reset switch is used.
C) Pin 9, 11, 13, and 15 are not used. Reserved for the factory.
D) Pins 2 and 4 are for the Power On LED (Light)
Pin 2 is for the Positive ( + ) wire.
If the PWR LED is dim when the computer is on, switch the wires around.
E) Pins 6 and 8 are for the Power On switch.
F) There is No Pin 10
There is No Pin 14
Pins 12 and 16 are N/C. Not Connected.
You can also see in the list where the Front Panel USB ports connect to (P - Front Panel USB connector), and the Front Panel Audio ports, (V - Front Panel Audio jumper )
The Power Supply used is a piece of Cr@p.
160 Watts. This is what it looked like,
http://www.ebay.com/itm/Gateway-E-3600-4000-Power-Supply-6500582-NPS-160CB-Test-/270707982390?pt=LH_DefaultDomain_0&hash=item3f07740036Gateway part number 6500704,
http://support.gateway.com/s/POWER/6500704/6500704nv.shtml(Click on Product View, and on Specifications)
It is approximately 6 Inches Wide, 3-1/2 Inches Tall, and 4-1/2 Inches Long.
When installed there is a green plastic lock, that swings over to lock the Power Supply in.
I would remove that green plastic lock mechanism, and use an ATX Power Supply.
All the same dimensions as above, except it is 5-1/2 inches Long.
ATX power supplies are used in a LOT of desktop computer, and readily available. A VERY common Power Supply.
Guess what else? You won't be stuck with a lowly 160 Watt power supply, or have to pay through the nose to get another piece of junk like it.
The Philips head screws in the back of the computer case, hold the Power Supply in just fine, without that plastic piece of junk, also.
An example of a Power Supply that would work, green plastic Lock removed,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1389575&CatId=1078430 Watt Power Supply will Not harm the computer.
Why?
Because a computer ONLY uses the power it needs, and NO more.
For additional questions please post in a Comment.
Regards,
joecoolvette
I need the wiring diagram for the front panel 3 power plugs on a Gateway 507 GR pentium 4 computer.
