Question about Sony Xplod XM-554ZR Car Audio Amplifier
I just installed my car audio system and need to know how to keep it from drainig my battery
Posted by jose52_magan on
Oloyede Monsuru
  • 1,468 Answers
there three ways which you can use as a precaution in favor or your car battery
from the indignation
from the car battery
and also the radio it self
the solution from the indignation what you have to do avoid battery drain after use is to make sure that all power indication from the dash board is OFF including the radio it self when ever you put off your car engine
then from the radio system the power switch most always be off after use and make sure that there is no form power on left .or disconnect the radio after use .
while from the car battery you will have to open the car brunet then remove the negative of the terminal from the battery it is smaller in size what i mean here is that you will have to remove negative wire connected to the battery with this there will not be any form of battery drain from the radio.
thank you and thanks for using fixya.
Posted on Jun 08, 2010
Battery keeps drainig overnight
You have a slow drain of power inside the car wiring. It could be a relay sticking closed, a short to ground somewhere, or a component using power when it should be switched off like a courtesy lamp.
The fuses have to be pulled to find the circuit with the drain.
Hi , hope someone can help. I am having problems with my eclipse avn 5500 navigation system reading the disc. It keeps saying check disc. Its the original disc not a copy. I did disconnect the car...
When the eclipse was installed the owner registered a disk for security reasons..... when power is disconnected the only way to resolve it is put the registered disk in!
1999 Chev Silverado 2500 Battery goes dead when not used for a couple of weeks
either you have no good battery or any circuit malfunction or any leak drainig the battery
I have a 2001 lincoln navigator and put in a new battery and now it keeps drainig it dead
YOU MAY HAVE A FAULTY ALTERNATER, WHICH IS NOT RECHARGING BATTERY FIRST CHECK THE DRIVE BELT TENSION IF LOOSE TIGHTEN IF NOT REMOVE UNIT AND TAKE IT TO A SERVICE SHOP FOR REPAIRS OR REPLACEMENT, NOTE: YOU MAY BE ABLE TO GET A USED ONE IN GOOD CODITION FROM A WREAKING YARD WHICH MAY COST WAY LESS THAN THE REPAIR OR NEW REPLACEMENT
Duration of nokia n95 battery is 4 hours with or without use
try to refresh the battery by drainig the battery until it shutdown and then try to charge it for 12 hours. if the proble is the same after trying this. then you need to replaced the battery of your phone.
2helpful
My washer has a little water left in the bottom of the drum and the washer has a smell of mildew. The pump is pumping great but isn't finishing the job. What would be the problem?
Hiya,
sometimes you can get a buildup of lint in the drainige system try checking the waist pipe & drainige pipes if you have a build up of lent in them or if the waist pipe is pushed to far down a drainige this can reduce the amount of water escaping & leave it in your machine or cloths the smell would be a sign of old water so those would be my surgestions to try & soilve this problem.
Hope this helps
Remove car alarm in 1998 ford escort?
Unfortunately i wish it were easy to remove the alarm system, but then, so does every car thief in the world.you cannot remove the anti theft system in any car,contrary to whatever someone may say.the brain is embedded in the cars electronic management systems.but you can remove the fuse......
I can't find the fuse for the audio system of my car in the fuse box, and it's not specified anywhere else in the manual either. I was wondering where it may be located?
I'm having so much trouble trying to install an after market system but I know where the audio fuse is for a 2002 nissan xterra. above the battery on the left. take of the fuse hood. left side half way down. yellow fuse w/ 20 on it. that's your audio fuse. mine keeps popping so we don't know what the problem is. hope i could help!
Ruud central air system
Install a condensate pump if you don't have one. Check to make sure it works if you have one and clean it out.
Sony Xplod XM-554ZR Car Audio Amplifier Logo
Top Sony Car Audio & Video Experts
 Francisco Mauricio...
 Grubhead
Grubhead
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
