Question about Acer Ferrari 4000 Laptop Notebook
Screen colour The screen colour has gone crazy (blacks are pinky colour, reds are smeared looking)...On one corner is a circle abit like a sun, its rays are pink. is here a solution?
    Guru:
  • 82 Answers
Check it to an expert. thank you
Posted on Jun 08, 2010
Testimonial: "thank you, very quick helpful response. much appreciated"
  • Anonymous Jun 08, 2010
    Thank you.
6ya staff
SOURCE:
Display has black circles lower left corner and upper right corner. were smaller but have grown. Maybe 2 in. each now. Also lines in pink and black across bottom. Everything else works OK. Bought past...
Well your on the right track I would say it's your LCD because your video chip wouldn't make black circles I don't think. The pink and black lines are a symptom of a LCD that has been broken and the circles sound like someone squeezed it to pick it up by the screen maybe. That would be for your venders warranty department to figure out though. If you really want to know you could buy a cable to hoot it up to an external video source if the display is fine, it's defiantly your LCD.
Jul 29, 2011 | Dell Computers & Internet
Have plugged in digital terrestrial receiver to tv and colour is a pinky red colour. Tv colour ok when digital box switched off
Check the scart connections are in tight (if that's what you are using). You may also want to try another cable. Also, make sure you have the correct input selected on your TV; the button on your remote should be either a circle or square with an arrow through it and possibly labelled source or AV.
Regards
Zahc
Jun 14, 2010 | Televison & Video
Screen pink red after installing mother board
uncompatible motherboard with many hardware,
1 - VGA screen card not compatible
2 - if VGA card is on board, then driver in the HD not compatible
3 - Screen resolution set to unsuported screen refresh rate HRTZ
Dec 06, 2009 | Computers & Internet
Toshiba Satellite L35 screen color turned to pink.
If you have a LCD-screen, not an old-style CRT-screen, it is the data-cable, and its connections, that are not transmitting one of the 3 "primary" colours, e.g., mix red & blue & green to get white,
but mix only two of those colours, and you could get pink,
because the mixing is an "additive" process.
If you mix NONE of the 3 primary colours, you should get BLACK.
If you see GREEN, you're seeing ONE of the primary colours.
Sep 19, 2009 | Toshiba Satellite L35-S2366 Notebook
I recently installed new black ink cartridge. Since doing so, the colors on anything printed are incorrect. For instance, anything red prints as pink. Anything deep yellow prints as a gold. MY...
Hi maryryherd - yes the C64 is in the list - don't know why you couldn't see it.
The inkjet colour system can be quite confusing. The colours in the cartridges are cyan, magenta and yellow, plus black. Other colours require a mixture of these basic ones. For example, to produce "red" requires a mixture of magenta and yellow. Your problem sounds like you are getting insufficient yellow, and maybe insufficient black.
Have you tried a cleaning cycle? If not, try one (right click the little printer icon in the bottom right corner of the screen and select head clean). Now run a nozzle check (right click the little printer icon in the bottom right corner of the screen and select nozzle check). Are all the 3 colour bands plus black printed OK. If not, try up to three cleaning cycles. If ink is now flowing pretty well, but not yet perfectly, don't carry out any more cleaning cycles. Just leave the printer for 24 hours (to allow any air in the print head to disperse). Then repeat the cleaning cycle/wait process. It may take a while to restore a perfect nozzle check print. If these actions produce no positive results, report back with a new comment.
Apr 18, 2009 | Epson Stylus C86 InkJet Printer
Second PC screen is a pinky colour
you need to set the temp selector on the monitor to the cooler temp.  It's in the monitor set-up controls.
Mar 25, 2009 | Belkin F1DL102P 2-port KVM Switch
Hp psc 1210 all in one colour problem
The cartridge may be defective. I had that happen so I returned for another and it worked fine
Aug 24, 2008 | HP PSC 750 All-In-One InkJet Printer
Television colour
your problem is simple it is called colour patch. it is basically due to change in direction or you must have shifted or tilted. it might be due to magnetic effect like spkr,telephone near by it.just remove from that location. put of the set for 15 minutes &put it on .problem will get clear. ask tv tech. to degauss it by dega.coil.it hardly 1 second job. regards
Sep 12, 2007 | Televison & Video
Colour adjustment
hi try lighten up the whole screen - its the "sun" icon and raise the contrast - its the half black hlaf white circle icon if it dont work , give us more details hope i helped
Feb 23, 2006 | CTX Professional PureFlat PR960FL 19...
Acer Ferrari 4000 Laptop Notebook Logo
119 people viewed this question
Ekse
Alun Cox
Steve Sweetleaf
Steve Sweetleaf
