NetGear WGR614 54Mbps Wireless Router (obwgr614_1) Logo
Posted on Jun 08, 2010
Secure wireless router - NetGear WGR614 54Mbps Wireless Router (obwgr614_1)
Anonymous
Level 1:
Problem Solver:
  • Contributor 10 Answers
  • Posted on Jun 08, 2010
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
10
Questions
0
Helped
854
Points
22
Default IP address: 192.168.0.1 Alternate Admin URL: http://routerlogin.net/ Default admin username: admin Default admin password: passwordtype ip in the address bar on internet explorer and type the login info than chose wireless you can set a wep key and you can also dissable wirless function
3helpful
The wireless network security settings on laptop do not match settings on router?
Hello.
- This error occurs when the wireless security that you set on the wireless laptop does not match the wireless security on the router.
  • If the wireless router's security setting is WPA but on the laptop you used WEP for the wireless security, that's when a mismatch occurs.
- What you can do to resolve the problem is to delete the wireless profile you created on the laptop. After that, let the laptop search for wireless connection available, select the correct wireless settings and it should connect.
--For example the operating system of your computer is Vista, in order to remove the wireless profile you created and reconnect to the wireless router, do the following instructions:- Go to Start>Control Panel>Network and Internet> Network and Sharing Center- Click on Manage Wireless Networks on the left panel. Delete the wireless profile then Search for available wireless networks again. Type the correct wireless security settings on your laptop
-- If you would like to know what wireless security has been setup on the router, connect the laptop or use a desktop which is wired to the router then access the router setup page by typing http://www.routerlogin.net or 192.168.1.1 in the address field of your browser and then press Enter. Enter admin for the router user name and your password (or the default, password).
--After logging in. In the main menu on the left, click on Wireless Settings, from there you can check the wireless security or you can setup wireless security from there if you haven't done so.
Hope this helps. Have a nice day. Don't forget to vote if you find this guide helpful. Thanks.
2answers
Where is the network security key
goto settings security ,now here enter the WEP key.
1helpful
3answers
Where is my network security key
My friend,
You have to lo-gin into the router setup page .
1.Put this address (192.168.1.1) in the address bar and then you will see the router setup page.
2.Then this will ask you for the username and password.
3.Username is nothing so leave this blank and password is admin.
4.Then you will see the router setup page .
5.Click on the wireless Tab under the basic wireless settings you will see wireless security .
6.Click on the wireless security and you will see there your router wireless security key.
7.Always select Security Mode as WPA2 PERSONAL.
8.If you want to change the security key you can.
9.After changing the settings Click on the sav settings.
Regards:-
Amit Awasthi
2answers
I want to secure my wireless conection
to secure your wireless register for www.opendns.com it can help secure your router wireless internet try it now
1helpful
How can i secure a BELKIN WIRELESS G ROUTER
Is there any computer connected to the router ?
If not then you will need to connect the computer to the router.
Do not change any wireless settings on the router with the wireless computer.
you will need to connect the computer to the router with the Ethernet cable.
check the IP address of the computer.
open the router set up page of the router.
Here you can change the wireless settings of the router.
Now once you change the network anme and security on the router, you will need to connect to the wireless network on your wireless computers.
Click Here for step by step instructions
Can't get access to my secure netgear router
If your computer does not connect to the wireless router, most likely the wireless card has not been configured with the router's wireless settings ie. SSID, encryption etc.
To secure your wireless network, configure the wireless router and the wireless card in the computer, please click on this link and follow my instructions :-
http://www.fixya.com/support/r3559128-wireless_router_security
2answers
Says not secure
To connect to your wireless router, it needs the router’s wireless settings configured and also needs the wireless cards in all the laptops and or computers to be configured with the router’s wireless settings. Then the laptops and desktop computers can communicate with your wireless router.
To set-up and secure the wireless router from unauthorized access, follow these steps: -
1. Connect the wireless router to your computer with a LAN cable.
2. Start your browser and enter the router's configuration URL IP address.
3. Enter the router setup, login and password
4. Change the admin password
5. Go to the wireless settings and change the default SSID and turn off SSID broadcast.
6. Setup encryption key the strongest is WPA2 (if not then WPA).
7. For further security measures - turn on MAC address filtering and enter the MAC address of the wireless cards on the computer/s you want to connect to this wireless router.
8. Record the settings you have made and keep it in a safe place and Save the settings.
9. Configure the wireless cards on the computer/s with the SSID and encryption settings of the router.
10. Remove the LAN cable between the router and the computer then the computers should be able to connect to the router wirelessly.
To access the Internet you need to connect the DSL or cable modem to the WAN (Internet) port on the wireless router.
1helpful
I DO NOT KNOW HOW TO SECURE MY MR814V2 ROUTER
Hello! To secure your wireless router, have a look at this Knowledge Base article below. This will guide you through the steps of how to set up wireless security on your exact model router.
MR814v2 Wireless Router Security Configuration Guide
Best of luck!
Security
Go to the router's web interface (192.168.1.1), in the wireless section go to Wireless Security. Enable WEP, you will create a WEP key for your wireless network, then that key will be asked to any wireless device that tries to use your wireless network.
Top NetGear Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
