Question about Hitachi 55VS69 55" Projection HDTV
First step is to unplug the 120 vac power for a few minutes to clear any corrupted data that may be present in the controller circuits.
If a "power" reset doesn't help and the lamp or bulb is installed correctly, you most likely have a failed replacement bulb. The symptoms are all standard indications of a failed bulb.
Reduced lamp life can be caused by:
Almost all Hitachi 55vs69 "No Picture" failures are related to the bulb.
Many of our service events are with customers that purchased El Cheapo bulbs from "shopping cart" websites or picked up a bulb from a small "local" TV shop. Many small shops stock of 3 or 4 bulbs and try to substitute or cross reference to fit more than 200 models of TVs from 7 different manufacturers. If a premature bulb failure occurs, they have the opportunity to sell you some expensive service.
Go here to see all of the different Hitachi TV bulbs that are available in Canada.
Find Your Lamp
Use the correct bulb for your model and if you are uncomfortable with the replacement procedure, get local service.
Posted on Jun 08, 2010
Mar 03, 2015 | Hitachi 55VS69 55" Projection HDTV
Jan 26, 2015 | Hitachi 55VS69 55" Projection HDTV
Mar 19, 2012 | Televison & Video
Mar 28, 2011 | Hitachi 55VS69 55" Projection HDTV
Jul 10, 2010 | Hitachi 55VS69 55" Projection HDTV
Sep 15, 2009 | Hitachi 55VS69 55" Projection HDTV
Jun 29, 2009 | Hitachi 55VS69 55" Projection HDTV
Apr 22, 2009 | Hitachi 55VS69 55" Projection HDTV
Apr 01, 2009 | Hitachi 55VS69 55" Projection HDTV
Jul 04, 2008 | Hitachi 43F300 43" Rear Projection...
Mar 06, 2018 | Hitachi 55VS69 55" Projection HDTV
Jan 19, 2018 | Hitachi 55VS69 55" Projection HDTV
414 people viewed this question
