Question about Maytag MGR6772 Gemini Gas Kitchen Range
Lower oven sits at 100 (Maytag Gas Double Oven)??
We have a Maytag Gas Double Oven Range (Precision Touch 750 Series). Model # is MGR6775ADS. This unit was purchased by the previous owner when we bought our condo 8 months ago, but I would assume at least a year has passed since purchase.
The top oven and broiler work fine, but the bottom oven just sits at 100...does not get hot at all.
Any suggestions would be greatly appreciated!
Posted by Ryan23 on
2 Related Answers
Anonymous
  • 725 Answers
SOURCE: I have a Maytag Gemini Precision touch 750 series
This sounds like your ignitor has gone out. The preheat will work because the valve doesn't have to ignite to heat to 100 degrees, but whent he unit is ready to ignite, the gas can't ignite it. If you will call or email us, we'll be sure to get the correct ignitor out to you asap so you have your oven orking right away! Thanksgiving is just around the corner, so I hope you get this repaired soon. We hope this helps and we hope to hear back from you soon.
Posted on Sep 30, 2009
Anonymous
  • 1531 Answers
SOURCE: I have a Maytag Gas
the part number is 74004565 it cost about thirty dollars from a local parts supplier.it should just be able to be pulled out and pushed back inplace.
Posted on Nov 21, 2010
Broiler shuts off
Make sure you keep the oven door OPEN when using the broiler, otherwise the thermostat will shut it off.
1helpful
I have a Maytag Gase Double Oven Range Precision Touch 750 Series and having a problem with temperature control for lower over how can I fix. Jim
Hello Jim,
Can you clarify the problem you're having, or how the temperature control issue manifest's itself, i.e. can't set temp in display, too hot, too cool, won't ignite etc.
Just some clarity to move you further, hope I can assist further.
thank you
Oct 27, 2009 • Ovens
3helpful
I have a Maytag Gemini Precision touch 750 series double oven range MGR6775ADB. The lower over is not responding. It will not preheat. The display says preheat and stays at 100. There is no flame igniting.
4helpful
2answers
5helpful
Oven wont work at all.
Convection oven and Bake will not heat past 200degrees. Broiler works fine and the range works fine.This is for the Model # MGR5875QDW, Gas Precision Touch Control 800, can you help. Thanks Kasz3
Open Questions:
Maytag MGR6772 Gemini Gas Kitchen Range Logo
Top Maytag Kitchen Ranges Experts
Vernon Taylor
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
