Question about Just Wireless Bluetooth Headset Wireless Headset
What is the BT-10K Bluetooth passkey - Just Wireless Bluetooth Headset Wireless Headset
Posted by jalfons2010 on
Anonymous
    New Friend:
The default pass key for the bt-10k is 0000 when pairing with handset. I was able to pair the bt-10k to Dell XPS with Vista without any pass key, after drivers were installer automatically. -jk
Posted on Jun 20, 2010
Mukesh Kumar
  • 3,230 Answers
Well the default pass key for most of the headset's is 0000 so you can try this .........
Good Luck!!
Posted on Jun 08, 2010
I forget passkey of jebra 108 bt bluetuth
Most modern bluetooth headsets use the pin 0000, if older maybe 1234. Other than that I would consult the devices instruction manual under the pairing area.
Rylan
Dec 15, 2010 | Uniden BT-108 Bluetooth Headset
Missing passkey info
it should be 0000 that is the default key for bluetooth devices and you can't change it on the earpiece
if it works for you don't forget to rate me
thx
Apr 28, 2010 | Emerson EM227 Bluetooth Headset
My phone is asking for a bt passkey. What is
Hi I sold cell phones for many years and I ran into this question many times hopefully I can help you.
BT passkey is your bluetooth passkey.
It usually is something simple like:
0000 or
1234
000
Hopefully one of these will work and you will be on your way.
please be kind and leave feedback that my answer was of assistance to you.
Mar 26, 2010 | Motorola Cell Phones
I need to put my samsung bluetooth (wep 301) in discoverable mode
Whenever you connect your bluetooth (BT) headset to a BT device:
  1. Set the BT device to search for other devices.
  2. While the BT device is searching and the BT headset is off, press and hold the call/end button on the BT headset until it's light is constantly lit and the BT device finds it.
  3. Enter passkey 0000 when asked.
Nov 07, 2009 | Samsung WEP301 Bluetooth Headset
Need passkey for the pairing for bluetooth with
The passkey in the Phone prompts up only when you are trying to pair your device to another device,
So, you can provide 1234 as the password and another user who is pairing with you should also provide the same,
Incase if it is not working under Generic key or if you are facing any other problem related to Bluetooth pairing, Please contact your Service Providor and check..
Oct 24, 2009 | RIM BlackBerry Storm 9530 Smartphone
How can i connect my bluetooth to my pc?
on pc side
1. give your host bt name
2. find bt COM port
My Computer->My Bluetooth Places->right click my device->Local Services->Bluetooth Serial Port
on phone side
1. give your phone bt name
then install pc suite and modem tool (if necessary)
restart computer
pairing
1. add device
host: go to My Bluetooth Places->Add new connection
phone: go to bluetooth, choose Paired Devices->add
2. provide passkey (4-digit, 0-9 only) on both
Check mRouter
check bt COM port that you found
Start bt serial
if you see mRouter turns green and blue, you got it
start pc suite
Oct 19, 2009 | Nokia 5000 Cellular Phone
Motorola i870
Try 0000 ...  That seems to be a "common" passkey for BT headsets...  That's Four Zeroes...
DLC
Oct 08, 2007 | Motorola Mobility H500 Wireless Headset
Just Wireless Bluetooth Headset Wireless Headset Logo
1,128 people viewed this question
Top Just Wireless Radio Communications Experts
Rocketmanusa
Level 1 Expert
Anthony Ward
Anthony Ward
robert
Are you a Just Wireless Radio Communication Expert? Answer questions, earn points and help others
