Question about Rockford Fosgate Punch 300X Car Audio Amplifier
Rockford Fosgate Hello sir, I am a student at the Mid-East Career Center in Zanesville Ohio. I am working on a gentleman's amp and when the mosfets went out, they exploded, leaving no trace of the numbers of the fets. It is a Punch 300s and I would love to have that manual I went to the site given w/o any success. Please help in any way Thank you very much for your time.
Posted by JoelDrumBum on
seankane89
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 54 Answers
If it is the power supply use IRF3205 and change the gate resistors to 47 ohm. Also replace the 4 power supply drivers.
Posted on Nov 07, 2017
3 Related Answers
mra85008
  • 182 Answers
SOURCE: Rockford Fosgate Punch 800 A2 shorting out.
replace the inputs on ur amp
Posted on Jun 29, 2009
Professor_V
Professor_V
  • 93 Answers
SOURCE: Rockford Fosgate Punch End CapsEnd Caps
I TAKE IT THAT YOU ARE REQUESTING A SOURCE FOR A PAIR OF ENDCAPS FOR YOUR PUNCH-200IX. IF THIS IS THE CASE, I SUGGEST THAT YOU CHECK EBAY ON A WEEKLY BASIS AS I AM SURE AFTER SOME TIME, YOU WILL SEE A PAIR LISTED. THERE IS ALSO A SELLER ON EBAY THAT HAS MANY OF THE LOGOS FOR THE MANY DIFFERENT MODELS THAT CAN BE PLACED ON ANY OTHER MODEL ENDCAPS FROM THE SAME SERIES (DSM, IX, X2, ETC. LET ME KNOW IF I MISUNDERSTOOD YOUR REQUEST......V
Posted on Jan 06, 2010
Anonymous
  • 25 Answers
SOURCE: Rockford Fosgate Spare speaker termal screws
if you have one that you can compare to another, go to home depot with that and match it up. If not, take the amp to home depot and get someone to help you find the right one.
Posted on Jan 29, 2010
1helpful
2answers
I have a Rockford fosgate punch p1000-1bd an it burn can you help me with the number of the mosfet in the power supply
Can't get your link to work. If you need a cross reference try mouser.com of digikey.com or mcmelectronics.com. if you want to have it repaired try linearpower.com. their sister company is t.i.p.s. and the owner is very well known for quality work.
2answers
Rockford fosgate punch 45 hd mosfet wiring
i have a punch 45 but i'm missing the speaker wire connector.... were do i go to get one...
2answers
I was using bridge on a Rockford P300 and blew my cheap speakers but now my bridge doesnt work. Bought new speakers and want to run in bridge mode is there a fuse inside maybe or did I blow it up?
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty. Your amp is clipping.
No internal fuses. Your mosfets are toast. A thumbs up would be greatly appreciated if this answer is helpful to you. using-bridge-rockford-p300-blew-peeu4x5nsxvd53n2rwetiqa4-3-0.jpg
I need a schematic for a RF p300-1 amp. Im trying to replace 2 of the mosfet semiconductors that got fried.
There are no schematics for RF amps, normally RF uses standard IRF Mosfets. Can you decribe the area where they blew, Power Supply are usually N-Channel high current type. Outputs can be either N-Ch or P-Ch depending on the Power rail there attached to.
Rockford Fosgate 801s Amp
depending on how good you are with electronics and soldering,you may be able to.i used to do warranty repair for rockford and they use mosfet semiconductors in the power supply.it is probably repairable cheaper than a new one,but by someone that knows how to do it.
3helpful
3answers
401s Rockford Fosgate Amp. Not powering on,just protect lite is on.
try hooking the remote wire to a rem wire on the back of stereo. post and let me know results
Quick question, amp problem
make sure you ground wires arent shared, meaning run each ground wire from each amp to its own grounding point
Rockford Fosgate Punch 300X Car Audio Amplifier Logo
Top Rockford Fosgate Car Audio & Video Experts
Daniel Dollive
Daniel Dollive
Steve Sweetleaf
Steve Sweetleaf
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
