The fuel pressure sounds too low. Is it multi-port injection? Check the fuel pressure against your specs for the car and engine. MPFI systems usually require 40-50 psi.
if the wiring to the sub is correct, then you have something wrong with the amp itself... something is power surging to the subs which is causing them to blow
passably the cover on you motor should stop water from getting in or you got old fuel, or bought bad fuel if possible water in fuel tank buy a bottle of heat this will remove water from fuel tank, replace fuel filter if one or drain moisture trap on engine fuel system.
check your engine colant temp sensor. it will tell your computer that its -66 and send loads of extra gass wich will flood it. couldnt explain the smoke tho
Sorry, Sony is having a lot of problems with the light engine ($$$) on
these models. Contact Sony as they are covering them even though
they are out of warranty (class action lawsuits)
