Lexmark X2500 All-In-One Printer Logo
Question about Lexmark X2500 All-In-One Printer
Replaced cartridge,get unsupported cartridge message,lexmark2500
I keep getting unsupported cartridge message wheb i relace a cartridge
Posted by dietluv on
Anonymous
    New Friend:
    Problem Solver:
I have a lexmark X2470 all-in one printer.I am getting the messarge reading"unsupported cartridge" It is a 3rd party refill.
Posted on Jun 11, 2010
I keep getting the message "unsupported right cartridge" on my printer. I have checked the installation a thousand times. Please help
Message signals that the right cartridge is not correctly recognized.
May have several causes:
1. Cartridge model is wrong (not a Lexmark color cartridge 33 or 35). In this case one must replace the cartridge with the printer.
2.
You use the correct cartridge but it is not recognized correctly. Try to clean the contacts on the cartridge and the printer with a soft towel or cloth.
3. If after you have cleaned the contacts you received the same message means that the cartridge is defective and must replace it with a new one.
2helpful
I have a Lexmark Printer z2400. i have a lexmark ink Cartridge that was working. now i get the message "unsupported Cartridge'. I was able to print a test page twice then it went back to...
that can be happened with some problem of cartridge or cartridge holder.
if you can check the printer with your older empty cartridge, and you can see
the different error message with that , it says your printer is OK.
and have some problem with your cartridge.and need to replace it.
if you can see same message with your old and empty cartridge,
you can clean both of cartridge the connecting pads ( in printer cartridge holder and
back side of the cartridge ) using by IPA and check again.
if had corrosion or some ink swallowed problem , can be clean with that.
after that if you got same result, you need to check your cartridge with
another printer or your printer with another good cartridge.
Hi, I have a lexmark x7170 and keep getting an error message "unsupported cartridge". Help please!!
If you receive an error message that tells you that you have an unsupported cartridge, then you need to remove the cartridge. After installing the appropriate type of ink cartridge you should no longer receive the error message and you can then perform a print test.
Instruction on how avoid unsupprted cartridge message.
  1. Lift up the scanner unit (with the power on). The printer cartridge carrier will move to the top of the printer into the loading position.
  2. Press down on the lever above the cartridge and then raise the cartridge lid. Remove the cartridge and make sure the cartridge supports no more than four colors (cyan, yellow, magenta and black) and a speed of 22 parts per notation.
  3. Insert the compatible ink cartridge into the carrier and then lower the cartridge lid. Close the scanner unit, then make sure plain white paper is inserted into the paper loader.
  4. Press the "OK" button on the control panel and the unsupported cartridge message should be gone. Press the "Select" button and a test alignment page will print.
1helpful
I have a lexmark 2580, I keep getting 'unsupported cartridge' message, and one of the lights on the printer is constantly blinking. I have brand new lexmark cartidges installed.
Problem Unsupported Cartridge; Error: "Unsupported cartridge"; Incompatible cartridge error; Incompatible cartridge in the printer; Cartridge not recognized Solution What you will see
When a cartridge is inserted, an Unsupported Cartridge error message is displayed on the printer operator panel.
Affected printers
This issue affects printers sold exclusively in the Dixon Store Group (DSG) in Europe and in Circuit City in the U.S. NOTE: The cartridges for these printers are sold exclusively in these stores or on their websites.
Explanation
The printers listed in the table below are compatible with a #2 cartridge (in single cartridge printers) or a combination of #2 and #3 cartridges (in two-cartridge printers). They do not support the standard color 28A 35, and Mono 29A 34 ink cartridges. If the standard color 28A 35 or Mono 29A 34 ink cartridges are used in these printers, they will fail to print and the printer will post an Unsupported Cartridge error message.
Solution
Lexmark recommends using either a #2 cartridge for single-cartridge printers or a combination of #2 and #3 cartridges in two-cartridge printers.
Cartridge compatibility chart
NOTE: These printers are sold exclusively in the Dixon Store Group (DSG) in Europe and in Circuit City in the U.S. The cartridges for these printers are sold exclusively in these stores or on their websites.
Item Printer #2 Color Cartridge #3 Mono Cartridge #31 Photo Cartridge 1 Lexmark Z738 Yes ... ... 2 Lexmark Z1380 Yes Yes Yes 3 Lexmark Z1480 Yes Yes ... 4 Lexmark X2480 Yes ... ... 5 Lexmark X2580 Yes Yes Yes 6 Lexmark X3480 Yes ... ... 7 Lexmark X3580 Yes Yes Yes 8 Lexmark X4580 Yes Yes Yes
Dell m5200 printer shows 32 unsupported print cart
hi there !
-try the old cartridge or a new cartridge and check if you will get the same message
-if you have the same error message it is a problem with the printer; if you the error disappears it is a problem with the cartridge; contact your manufacturer for a replacement cartridge
Unsupported cartridge error
Sounds like a falty cartridge. Call Dell tech support. The cartridge should have a warranty even if the printer iself does not. They'll replace it.
Lexmark 2300 i keep getting unsupported cartridge message although using lexmark no 1 cart
99% of the time, the cartridge is defective. Try another cartridge, even if the one giving you the error is new. If the other cartridge works, then return the new one to the manufacturer as defective.
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Marvin
Marvin
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
