Question about Zapco Reference 750 Car Audio Amplifier
I have a zapco refrence 750.2 has no sound output when bridged but works fine when i run a speaker to each channel. any ideas on whats wrong?
Posted by p_en03 on
Frank Rossiter
    Guru:
  • 403 Answers
Check your settings on your stereo and the amp make sure you have changed to 1 ohm on the amlifier for a briged connection to a subwoofer and change from lpf to hpf on the amp there should be a switch.
Posted on Jun 08, 2010
Harman Kardon AVR 25II no sound from left channel
Sounds like the left channel has blown in your AVR 25II. If it was a faulty headphone jack it simply wouldn't send an output signal to the speakers.
Oct 01, 2018 | Harman Kardon Audio Players & Recorders
I installed a 400 watt zapco competition amp\ front speakers play ...back woofers don't?
are you sure you didnt wire the amplifier the front and rear to
left/ right?
check your deck settings to see that the rear speaker rca are connected.
check all wires are connected.
push the mono or bridge buttons are off.
provide more info.
Nov 03, 2013 | Zapco I-450 IFORCE SERIES 4 CHANNEL CAR...
Which amplifier is best suitable for me to use?
This really depends on the setup you intend to create in your vehicle.
The Amplifer (amp) needs to be matched to the speakers you intend to run.
As a rule of thumb, the power of the amp shouldn't exceed the max. power of the speaker (this may damage your speaker). Instead, the amp's RMS output power should be at 75-100% of the speaker's RATED (RMS) input power. NOTE: this must NOT be confused with max power.
Ideally, you want to run each speaker with its own amp channel.
A subwoofer will usually require a hi-power single channel amp, or a 2 channel amp, bridged into 1 (to increase power output required for the sub).
Here are some examples in simpler terms:
1 channel (hi power) amp can run a subwoofer.
2 channel amp can run 2 speakers, or 1 sub (bridged).
4 channel amp can run 4 speakers, or a combination of 2 spkrs + 1 sub (bridged), or perhaps 2 subs (bridged).
Hope this makes sense.
Feb 27, 2013 | Car Audio & Video
How to bridge NAD 7150 with 2150
Bridge connections
Using 2150 as a slave
Sep 09, 2012 | NAD Audio Players & Recorders
I have a Behringer PMP 6000 that I just bought. With the power amp switch in Main L/Main R it works fine, but if I switch it to Main/Mon, only the Mon works, nothing from the Main. Bridge mode doesn't...
Bridge mode you use chan B (left connector on the back) using a SPECIALLY wired Speakon. The impedance of a speaker connected as such CANNOT be LESS than 8 ohms.
In the Main/Mon mode, the two amplifiers are separated in function. The monitor knobs for EACH channel input control the mix sent to Channel A which is for the monitor speakers. The Mon1 controls the level sent to Output A for the monitor speakers. Mon2 fader is NOT used.
The individual channel faders control the main mix and the Main fader controls the level sent to Output B which goes to the main speakers.
Apr 02, 2011 | Behringer Pmp3000 16 Channel Audio Mixer
CROWN CE1000- slips into fault immediately after connection
if ur output power amp is defective u will have that problem - meaning the moment u connect load across it it will go into circuit protection to limit/stop excessive output current. make sure the speaker terminals are connected to +/- output terminals. in bridge mode use only channel 1 and that too with 4 ohms speaker only otherwise amp will clip. considering all connections are okay if it still clips when speaker is connected, u have a faulty power amp section. this the way ur amp is designed
Apr 05, 2010 | Crown CE1000 2-Channel Amplifier
The linksys utility always sends signal to PC speakers, even when wmb54g unit shows connected. The wmb54g and router are up-to-date and run WEP 128 security encoding. The wmb54g flashes faster when...
I can disable the sound card, set the music bridge as the default sound output device and it works just fine (after rebooting). But if I enable the sound card again, even when keeping the music bridge as the default, the sound goes exclusively to the PC speakers, no matter what device the connection is switched to on the Linksys utility. (By the way the music bridge shows correctly to be connected or disconnected....with no effect on the sound output.) The major hassle is that any usable change of output device requires a reboot. Still testing. Not a single answer from the community. Also I never required the promised temporary password.
Dec 25, 2009 | Linksys WRLS BRIDGE |WMB54G MUSIC R
Zapco DC Reference 750.2 problem
If the amp uses TIP35Cs and TIP36Cs, those will be the output transistors. Measure the resistance between legs 2 and 3 for each of the output transistors. Do any read near 0 ohms?
If you're new to repairing amps. The following page should help.
http://www.bcae1.com/repairbasicsforbcae1/repairbasics.htm
Nov 16, 2009 | Zapco Reference 750 Car Audio Amplifier
Can I run two E.V. Eliminators (1-15 and horn...8 ohms) in series from the bridged output? What my wattage be? I have an EMX5000 powered mixer. Jim Price [email protected]
Hi pocket218
Probably not the way to go about hooking it up. running speakers in series is not very practical with PA gear. The connections get messy to make as you need adaptor leads, and it is something that is seldom ever done.. When you use bridge mode it uses left and right channel together to drive the one output, combining the power. Best bet is to run the EMX5000 in stereo mode, and connect 1 speaker to each channel. You may have been trying to reel in extra power from using bridge mode, but the power amp stages in the EMX will only ever be able to deliver the same MAX power whether in bridge or stereo. the best way to get maximum power and sound pressure levels from the unit is to hook TWO speaker boxes to each channel, you get the combined increase in efficiency of the extra speakers and run the output stages at 4 ohms to get absolutely all the power available
If you have any questions about it, feel free to ask me, happy to talk to you further about it.
regards
robotek
Sep 11, 2008 | Yamaha Audio Players & Recorders
On lucent amps you sometimes have to bridge two terminals together to make it work. i need to know what two need to be bridged.
I'm not sure if Lucent has a special bridging procedure, but on most if not all other amps, when you bridge you DON'T connect two terminals together. What you do is instead of using the plus and minus terminals on one channel to one speaker and the other +/- terminals to the other speaker, you will instead use the plus (+) terminal from one channel and the minus (-) terminal from the other channel to drive one speaker and the remaining + and - terminals remain unconnected. Be sure you use the + and - terminals that are marked for bridging. Please note, that when you bridge that your speaker load DOUBLES to EACH channel. In other words, what your amp saw as a 4 ohm speaker going to one channel alone, it now sees as a 2 ohm speaker on each channel when bridged. Be sure you know what you are doing before you bridge and fry your amp. In my experience, if after bridging your amp works fine for about a month and then fries then you bridged wrong and ended up with the wrong speaker load on each of the bridged channels. Be careful. Amps cost a lot to repair. Good luck.
Jun 02, 2008 | Audio Players & Recorders
Zapco Reference 750 Car Audio Amplifier Logo
162 people viewed this question
Top Zapco Car Audio & Video Experts
Marvin
Marvin
Are you a Zapco Car Audio and Video Expert? Answer questions, earn points and help others
