You need a RCA sub-woofer cable (analog mono) to connect between the receiver's sub-woofer Pre Out and the sub-woofer. This cable has a single RCA plug at each end of the cable. The cable is somewhat thicker than some audio RCA cables. You can use any RCA cable temporarily.
Unfortunately, I don't think you can connect this sub-woofer without the rest of the components of the HTS3440/37 DVD Home Theater System or a related Philips home theater system. The speakers in the system are hard-wired with a colored plug that you connect to the sub-woofer. Then you need connect the inter-connect cable between the sub-woofer to the DVD Player of the system. See the wiring guide in the Quick Start Manual or the User Guide available on the product support page: https://www.usa.philips.com/c-p/HTS3440_37/divx-ultra/support .
Even if you find another Philips Home Theater system that is missing the sub-woofer, I wouldn't rule out a change in the pin arrangement for the inter-connect cable that would cause the system to fail. I can't find any sources for a replacement inter-connect cable; the part number isn't in the manual that I can find.
The simplest thing would be a like-for-like replacement. Ebay or Craigslist would be good sources if the sub is out of production. There's one listed on Ebay UK for 39 sterilng. Item number 171423774447 - ends 16th Sept 2014
For new replacements the answer depends partly on how you connect and then partly on where you live. I'll deal with connections first...
The JVC has both high-level -speaker cable sockets- and low-level -phono/RCA- connections. Budget subs with both sets are getting rarer in the UK.
If you are connecting from an AV receiver with the low-level phono cable then the Tannoy SFX sub would do quite nicely. It's 99 sterilng at Richersounds.
For a sub with high and low level connections then the Wharfedale Diamond sub is about the cheapest in wide distribution. 170 sterilng at Tesco, 150 sterilng as an open box special at Superfi. Personally though, if I were considering spending 150+ on a sub I'd go the extra mile and plump for the BK Gemini at 215 sterilng direct from the manufacturer. You're getting 300+ sterilng performance because they cut out the middleman.
If you live in the US then there's a bit more choice. Have a look at Bestbuy. The Pioneer SW 8mk2 isn't bad at 159 dollars. There's the Theater Solutions SUB6F at 88 dollars if you just want cheap. Respected speakers brand Polk has the PSW 108 at 199 dollars
Most power cables are universal with only a handfull of different types. You could check if power cable for your sub woofer is the same with same amount of pins(2 or 3) and if its the same you could use your system without the woofer for now.. Just about any Electrical Dealer shop(ie.. sells tv's,computers etc) should have a replacement cable for you- just take in the end that connects to your stereo.
nothing is wrong with the woofer the connect is broken at the strain relief and the cable needs to be replaced. You can replace the connector if you know the pinouts. You will need the connector and the schematic. you may be able to find the pin outs configuration here. http://pinouts.ru/ As for the connector this may take a search online.
The Boston Micromedia speaker set comes with two speakers (right and left),a subwoofer, and a complete set of cables to connect everything up.
1.) Position the speakers. The two small speakers typically are spaced equal distance apart on a desk/table top to the benefit of the listener. The sub-woofer typically rests under the surface, on the floor for example.
.) Connect the cable sets to the back of the two small speakers along with the speaker feet. Note: the small speaker with the volume control knob will have three cables coming from it. This will be the "right" speaker. The other speaker will have a single cable and will be the "left" speaker.
2.) The cable ends will be color coded to match the jackson the sub-woofer. Match up the color coded cables to the respective colors on the subwoofer as follows:
(a) White cable end (left speaker) to white jack on sub-woofer. (b) Red cable end (right speaker) to red jack (c) Purple cable end (input) to the purple jack (d) Green cable end (computer out) to the computer's microphone output jack.
Note: if any of the cables are too short to reach their jacks for whatever reason, an extender cable with a female and male end can be purchased relatively inexpensively to make up the difference in distance.
3.) Power up the system (plug in power cables to the sub-woofer and wall), play some music, and adjust the sub-woofer sound (control knob) to suit listening pleasure.
A nice little set of speakers, I had mine for some years now and continue to enjoy them. Good luck!
The amps are 8-pin CHN 4558CN [K1D142]
and 8-pin PHIL TDA8199 [LD8136]
The Voltage Regulator is a 14-pin LM324N
There is a 3-pin LM7812CN 12-volt regulator...
They are in the sub-woofer housing which is held in place by tape so it can be pried off if done with care.
Hope this helps.
If you have all the cables and wires in place I would appreciate knowing the connection sequences (someone cut all the wiring to the set I have.)
This should not be a problem. Cut off the plug off the wire oppisite the sub connection. Turn on the sub and touch each wire till you hear a buzz, that should be your source wire. Connect up an RCA plug with the ground of course, and you should be set. Good Luck
