As far as video connections you can use either one of these connections
As far as audio, you can use the 2 RCA outputs (left - right) marked with the number 4 at the following diagrHelp!! Would like to use my ks3102 as a dvd only. - 77db946.jpgg src="/uploads/images/77db946.jpg" alt="77db946.jpg" class="h_mi" />
Connect these 2 RCA outputs either at the tv's audio in (in case there is one) or use a scart to RCA (with SVideo connector) adaptor (you can ask for this at your local tech store). Use this adaptor at the scart port of the tv and connect at the adaprtor's RCA the RCA audio outputs and the SVideo at the SVideo (number 8) of the DVD player.
In case of a problem or clarification, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
