I bought a vintige looking popcorn popper on a cart. when we first bought it, i would need to trun the kettle on for about 5 minuted before the spinner would start spinning, then i would put my kernels in. but just last week, it stopped spinning, i could have the kettle on for an hour with nothing. I think i might be the motor. any suggestions? thanks in advance.
If when you pick up the kettle to dump it you can spin the agitator in the pan with one hand easy then it is not stuck. check to make sure the motor switch is supplying voltage to the motor. If that is ok now that you have the front panel off look inside to see if the motor is turning but the drive head which comes up thru the pedistal isnt then the motor shaft pin has sheered off. if nothing is moving at all motor needs replacement. the list on those from the factory are over 600 so make sure its bad first.
Any Creators dealer would be glad to sell you one but when you hear the price you will probably consider repairing yours. Even if the pan itself is bad , I have still repaired them for much less than purchasing a kettle complete.
The thermostat built into the kettle stops the kettle from heating at a prescribed temperature. usually around 425 F. This is hot enough to smoke and cause instant burns, but is the required temp for popping popcorn.
I do not know of a "thermal fuse" built into popcorn machines. Mechanical thermo stats are not flawless. they can and do malfunction, either too cold or too hot. the model popper you have is not adjustable, or repairable.
If you are tripping a electrical circuit breaker that is a different problem not related to kettle heat. It is a symptom of an overloading problem of your outlet, or a ground fault in the popcorn popper.
The profiteer kettle is held upright from the gas spring/shock type unit opposite the handle. It is very common for the spring to wear out and the kettle to sag after time. I see them replaced about every 2-3 years on that model.
Replacing the return spring will bring the kettle back up to it's horizontal popping position.
Have a look here http://www.amazon.com/Nostalgia-Electrics-CCP509-Full-Size-Popper/dp/B0000CFW9M
Perhaps your problem like this?
When the kettle is popping popcorn, the metal rod with gear on the end pops out of place. Therefore, the kettle stops spinning and the popcorn burns.
>The allen screw that holds it in place need to be tighten.
When Popper Has Popped Corn Just Before. 1. Pour the properly measure amount of Oil into the kettle. 2. Wait about 45 seconds - or until the Oil in the kettle starts to smoke slightly. 3. Pour the contents of the properly measured corn cup (kernels plus popcorn salt or Flavacol) into the kettle. 4. Wait about 2 1/2 minutes. If you are using a pan on the stove without an agitator, you must constantly shake gently. When the crackling noise of the popping corn is no longer heard, dump the kettle and empty it completely. 5. Repeat if needed for more popcorn. 6. When you are finished popping, turn off the kettle agitator switch (if you have one) and turn off the Pilot light/ heat switch. 7. After the machine has cooled enough so as not to be dangerously hot, wipe the outside of the kettle with a soft damp cloth. This helps prevent a heavy build-up of the Oil.
TIPS - Bagged floss keeps a day or two, depending on the humidity - Use bags to make and display cotton candy in advance - use cones for immediate sales - Unless you're experienced, it's best to turn off the motor to refill the spinner head - If machine will be used more than 20ft. from power source, be sure to have an adequate extension cord
